this is new
Old Nov 1, 2003 | 05:45 PM
country's Avatar
this is new
today i was @ home depot , went to back out of the parking space ,when i put the truck in reverse it just cut off , everything died , turn the switch off and it restarted , put it back in reverse and died again, this time it didn't restart , so under the hood i go , lookin around for a minute then i heard a click like a relay resettin, tried it again and fired right up and been running flawless ever since. although i do notice that when i shift into R that the voltmeter pulls down. what in the world would cause this. and what would be drawing power in reverse?
Old Nov 1, 2003 | 09:57 PM
chrisguthrie's Avatar
Re:this is new
your reverse lights but i can't see that killing the truck. Have someone stand back there and see if they work when you shift into reverse? That's all i can think of. They may be grounding out somewhere.
Chris
Old Nov 1, 2003 | 10:20 PM
country's Avatar
Re:this is new
yea they still work
Old Nov 2, 2003 | 08:43 PM
country's Avatar
Re:this is new
TTT
Old Nov 3, 2003 | 12:33 AM
Bushy's Avatar
Patron Saint of 1st gens
Re:this is new
Ok, I REALLY SUCK at electrical stuff but you need some action on this one so...here goes...
Check the relays on the drivers fender. There should be at least three of them. I can't recal which is which but check the connections.
Next check the connections on the battery. If the battery is bad or has one bad cell it will cause this.
Next the manifold heater sensor may be triggering your heater block on the intake manifold. Is it getting cold in your area??
Is your idle high enough?? It should be rougly 775-850 RPM in gear (for an auto) and 750 - 775'ish for a 5 spd.
Make sure that the shifter linkage is not pinching any wires causing a short.
The clicking is obviously a relay so start with those and go through them all.
Bob
grishfish
113
Mar 3, 2013 10:53 PM
OOPS
Aug 28, 2004 07:15 PM
powerwagon440
Apr 19, 2003 07:19 AM
midwestdually
Mar 21, 2003 09:06 AM
akchameleon
Mar 19, 2003 12:39 AM
