Needing help moving the o/d off button
Old Aug 3, 2009 | 08:45 AM
TJE's Avatar
TJE
Originally Posted by 93flatbed
So if you press the button the meter will move from OL to 0.1 OHM's? Or it will only read if you are still holding the button in and when you let go of the button it will go back to OL? If that's the case then I think you have found your problem.
Justin
exactly! once I release the button it goes back to 0.0 ohms.
Old Aug 3, 2009 | 09:15 AM
M1Lover's Avatar
An ohmmeter indicates resistance to current flow in ohms. Zero ohms means that number 1 wire is completely connected to number 2 wire with NO resistance. As if it were just one wire.... That make any sense?
Old Aug 3, 2009 | 12:07 PM
TJE's Avatar
TJE
Yeah I got the ohm's thing figured out. There is no reading when I check the button. I have to continuely hold the button in before I get any reading at all. I checked at the dealer and the button is $20.00
So I guess that is the next step.
Thanks, Tony
Old Aug 3, 2009 | 06:04 PM
Sounds to me like the button is working properly. It's a momentary switch, you don't have it connected properly. Go back to my earlier post and connect it the way I explained.
Old Aug 3, 2009 | 07:24 PM
TJE's Avatar
TJE
Dave I'm scratching my head on this one. I have one black wire from the shifter connected to the yellow/black, and the yellow/green. I have the other black wire connected to a ground. The orange/yellow, and the dark blue wire are not even connected at this point! The result is only when I hold the button in will the tranny shift out of O/D. Sorry guys for being so ignorant but I've been over this thing till I don't know what else to do.
Old Aug 3, 2009 | 07:35 PM
TJE's Avatar
TJE
Well get out the idiot hat because it clearly belongs on my head. After my reading comprehension finally started to work I realized what the problem "WAS"
I wired one black wire from the shifter to the yellow/black and the second black wire from the shifter to the yellow/ dark wire. Well guess what....it works like it should.
Thanks Guys,
Old Aug 3, 2009 | 08:45 PM
93flatbed's Avatar
Wow I'm sorry to lead you down the wrong path. I didn't know it was a momentary switch. Thought It was an on off. Sorry I guess I will keep my mouth shut Unless I really know something.
Sorry again
Justin
Old Aug 3, 2009 | 08:56 PM
TJE's Avatar
TJE
Sorry again
Justin
No problem....I still don't have a clue about how it is working, but hey it is working, that is all I wanted. Momentary switch...you got me there.
Subliminal
Jan 21, 2014 09:55 PM
Tedonlin150
Feb 4, 2010 11:37 AM
Twodiesels
Jul 11, 2009 01:12 PM
can17
Nov 10, 2008 02:53 PM
DF5152
Dec 25, 2003 12:05 AM
