NEED TWO PART NUMBERS and SOURCE
Old Nov 4, 2008 | 05:24 PM
BearKiller's Avatar
Question NEED TWO PART NUMBERS and SOURCE
This is for a friends 93W-350.
The tie-rod/link whatever it is called that connects the Pitman-arm to the knuckle, ?drag-link maybe?; I have a number = MOOG DS914; is this correct ??
Also, recently someone posted the number for the little U-shaped boost tube that connects intake-manifold to AFC housing; what is that number and is it Cummins or Bosch ??
He has been driving this truck around for five years and today I noticed that someone had pinched off the tube at both ends for whatever reason, maybe a permanent valet-switch.
Thanks.
Old Nov 4, 2008 | 09:39 PM
gear jammer 91"'s Avatar
I think there are a bunch of moog part numbers in the sticky you could check the one you have against. Of course if that's where you found it then I have no idea if it's still good.
As for the boost tube you can make one out if brass fittings and some tubing.
Old Nov 4, 2008 | 09:41 PM
PapeCAT's Avatar
I'd try and locate an adjustable drag link so you can center the steering gear.
Old Nov 4, 2008 | 09:42 PM
Montana2x2's Avatar
DS 914 is the correct # for w-250 not sure if it works for the 350. Cheapest place I found it locally was NAPA around $70 IIRC.
bullboy85
Feb 11, 2011 08:49 AM
roxxx
Sep 21, 2009 08:52 AM
TxDiesel007
Jul 2, 2007 06:16 PM
crobtex
Oct 15, 2006 09:59 PM
crossy
Jul 18, 2006 05:18 PM
