Need Correct Part Numbers and suggestions needed
Old Jul 2, 2007 | 09:46 AM
TxDiesel007's Avatar
Guys
if anyone has the correct part numbers from NAPA or any reputable parts seller, i need the part numbers for the tie rod ends for my pickup.
IF not napa, does anyone else have any suggestions for good tie rods for the truck? this weekend they are goin in as well as the thuren trackbar...
Any other suggestions for fixin this front end and fixin it right? How does one know if the ball joints are bad too?
truck is a 96 2500 4wd.... 192K miles
TY in advance!
Rick
Old Jul 2, 2007 | 09:59 AM
John Faughn's Avatar
Have you looked into the Lukes Links ?
With the ball joints , get the ft end off the ground , grab the top & bottom of tire , push one while pulling the other , if you feel any slop , with some experience you can judge how bad / how many miles you can get , then also a 3' pry bar , and pry between ball joint & axial , side to side .
Here's a link for parts & other related .
Old Jul 2, 2007 | 11:37 AM
Not quite
im still lookin for the actual parts for the truck. I need the tie rod ends to redo the whole front end. Hadnt even thought of lukes links..
I wanna do the front end once, and do it right (now that i can afford to)
Rick
PS so on a serious note, what is needed to fix this front end and fix it right 100%?
Old Jul 2, 2007 | 12:15 PM
robert chilton's Avatar
Advance auto carries TRW and I believe that they can also get moog. Check out their site as it is throught parts america. Rockauto.com is another really good source if you have a few days to wait. I would suggest changing the front springs, shocks, and the swaybar end links while you are in there. The endlinks made a world of difference on mine being they help locate the axle.
Old Jul 2, 2007 | 12:31 PM
signature600's Avatar
www.thurenfabrication.com
Crossover steering and Tracbar
Chris
Old Jul 2, 2007 | 12:50 PM
Shocks are brand new
Swaybar end links need tending too, i know that for sure... Springs are less than a year old as well...
Chris (signature600)
where u been man? whats goin on? THanks for the suggestions... Ill see about that crossover steering... call up Don see whats up...
Rick
Old Jul 2, 2007 | 06:16 PM
I spent last week in Kansas without a computer...so basically, I was dead!
Chris
robert78.5
Aug 26, 2008 10:41 AM
Mopar1973man
15
Jan 7, 2007 11:07 PM
banzaitoyota
Jul 31, 2006 07:01 PM
