need some help
Old Dec 17, 2006 | 12:57 PM
Joes truck's Avatar
need some help
Hi kinda knew to this site. My brother is looking at a first gen dodge truck. auto,4x4,longbed reg cab. problems is the guy were thinking of buying it from says theres diesel fuel getting into the engine oil. any help would be great thanks. Joe
Old Dec 17, 2006 | 01:07 PM
There are two main causes for this. The first is easy and cheap, the second not so easy but less common. Most likely the diaphragm in the lift pump is torn and the fuel is getting in that way, it will take you about 45 minutes and cost you around $60 to replace the lift pump. The next most likely culprit is the front seal on the injection pump, which is more involved but less expensive.
Old Dec 17, 2006 | 01:14 PM
John Faughn's Avatar
wannadiesel
Its too late now but where are the $60 LP , I paid $95 and thought that was good .
Old Dec 17, 2006 | 03:07 PM
59FORD's Avatar
ALL day long at my parts store but I do have a business account
Even the thieves at Da' Zone are only $72
Old Dec 17, 2006 | 05:20 PM
If you want a genuine Cummins pump $95 is normal. Aftermarket ones at chain auto parts stores are around $60, and usdieselparts.com sells a Delphi unit for around $40 after shipping.
Old Dec 17, 2006 | 06:51 PM
dpuckett's Avatar
I paid $80 or so a few years ago for a "genuine Cummins" lift pump. Opened up the box, and it was the exact same Carter pump I could have bought at the local parts house for $15 less, plus saving a 2hr round trip. The guys at Sikeston are crooks the same as the dealer.
Daniel
Old Dec 17, 2006 | 07:03 PM
mooktank's Avatar
why not grab a piston style pump off ebay and be done with it? Theyre like $45.
Old Dec 18, 2006 | 06:21 AM
Joes truck's Avatar
thanks for all the help very helpful info this is a great site. Where do I need to go to get the seal for the injector pump, is it availiable at napa or some place like that thanks again. Is there any place on here that tells about removal of the injector pump thank
Old Dec 18, 2006 | 03:43 PM
Change the lift pump first, it's much more likely and it's a whole lot easier.
You can get the injection pump seal from a diesel fuel injection shop.
There are several threads on injection pump R&R.
Old Dec 19, 2006 | 06:23 AM
Joes truck's Avatar
thanks a lot for the help
Old Dec 19, 2006 | 09:18 AM
willieboy's Avatar
What seller is selling them for $45? All of them I see are $100+
Old Dec 19, 2006 | 11:15 AM
dpuckett's Avatar
I've seen them for $45. Type the part number in the search box and it comes up, or did a few months ago. I have been told they are seconds, but if you get one that doesnt work, he swaps them out reasonably.
Daniel
bsj04
Sep 20, 2007 08:09 AM
Mini_Donkeys
Apr 19, 2007 12:21 PM
TxDiesel007
Nov 29, 2006 12:08 PM
SilverHoss99
Oct 31, 2005 07:22 PM
JKM
Mar 4, 2005 03:33 PM
