Need some direction please..
Old Sep 16, 2007 | 05:31 PM
SMoKeNU's Avatar
Hey guys i got the old girl this year for work (towing a 22' trailer full of equipment) it definitely was a huge improvement over my S10..haha... Now winter is coming up and i want to go through it and fix some problems for next year so this is were the questions come in.
I have a oil leak that is really bad. Its hard to see where its coming from because i power wash it and then go for a drive and by the time i get back home the oil is everywhere (all over the fan and alternator basically the whole front of the engine) Its not coming from the injection pump or the air pump or whatever its called so can anybody point me in the next place to look? I want to get the parts ordered now while i still have money before winter hits.
Second question is although it pulls allot better then the S10 it still has some problems getting up some hills. What can i do to help this situation a little?
And the last part and if you are still reading this i appreciate your patience! Sometime when im on the freeway towing to my next job going about 75mph the old girl gets really hot! It gets to about 3/4 of the way on the temp gauge sometimes higher. The truck is completely stock so im not sure why the egt's would be getting that hot specially since i haven't touched the pump YET! Is this a big problem i should be looking more into?
Thanx again this site and the people are the best!
Old Sep 16, 2007 | 06:27 PM
taterfarm's Avatar
If you want some free power to help with the hills then play with the pump. As long as you have your piro that is. here is the link from the sticky on pump adjustments.
http://dodgeram.org/tech/dsl/more_power/Power_ve.htm
have fun.
Old Sep 16, 2007 | 06:53 PM
SMoKeNU's Avatar
Thank You! I will mess with the pump and see what i can do. What is the max EGT you want to see? And what is a good balance of being safe and performance.
Thanx
Chris
Old Sep 16, 2007 | 06:57 PM
Does it seem to be coming up from the bottom or down from the top?
Pull the fan hub and look for a crack in the timing housing from a dropped KDP. Could also be the front crank seal.
Old Sep 16, 2007 | 07:02 PM
SMoKeNU's Avatar
Honestly i would say its coming from the bottom but man the oil is everywhere including the hood. It could be the fan catching it i guess and throwing it around. Where can i order a new front seal if that is it? If its is a cracked housing im guessing i have to look into a junkyard?
Thank You
Chris
Old Sep 16, 2007 | 07:05 PM
Cummins can sell you both parts, so can your local Case equipment dealer. Why not clean the motor off, pop off the belt, and idle it for 5 minutes or so to get a good fix on the location of your leak?
Old Sep 16, 2007 | 07:17 PM
SMoKeNU's Avatar
Will do thanx for the help ill get back to you to let you know what i find.
Chris
Old Sep 17, 2007 | 01:28 AM
KRB's Avatar
KRB
Could all that oil be coating your radiator and plugging it up?
Old Sep 17, 2007 | 07:16 AM
SmokemS's Avatar
smokenu.........u came to the right place.....wannadiesel and the rest of the DTR boys(and girls) are the most knowledgeable people i met so far..........
Old Sep 17, 2007 | 06:00 PM
SMoKeNU's Avatar
ya this place is great and so are the people. hey i like your name!
I dont know if the oil could cause the truck to overheat like that its fine unless im driving on the freeway doing 75 maybe the truck just cant take that speed with a trailer?
Im going to powerwash the engine and do what wanna said and see where that problems lyes first. If only i could get a minute now from work.. or the kids hmm or the wife. Oh i did not just say that!
Gotta go
chris
Old Sep 17, 2007 | 06:11 PM
SmokemS's Avatar
i have an oil issue also.....but i think it is my main rear seal but i heard even if u fix it......its not guaranteed to fix it
Old Sep 18, 2007 | 04:57 PM
Get the kit with the repair sleeve and follow the directions to the letter - it won't leak.
Old Sep 18, 2007 | 05:28 PM
BearKiller's Avatar
First thing = install a decent mechanical water-temperature gauge and see what it is actually doing.
I don't have a lot of confidence in the accuracy of the factory gauges.
I didn't see whether the truck is manual or auto.
If an automatic, it can transfer a ton of heat to the coolant, when towing.
The radiators that come in these trucks are -- to my way of thinking -- way too small; and, I hear many complaints of running hot when towing.
Does the truck have a pyrometer ??
Pre-, or post, turbo ??
Old Sep 18, 2007 | 05:35 PM
SMoKeNU's Avatar
Truck is a manual. I'm in the process of looking for a reasonable prices pyro, boost, and was going to get a oil pressure but maybe water temp instead. Do you know of any reasonable prices gauges i can get? I have some DEFI gauges but i really don't think i want to install those in my work truck.
So is there a upgrade radiator for our trucks? If so were is a good place to pick one up?
I love my truck even though im new to the cummins im finding that it is allot harder to find after market parts for it then it is my evo
Oh and what location does everybody prefer to mount the pyro? Cylinder 1 or 6 before the turbo?
Thanks for the advice and will be looking forward for your input.
Chris
Old Sep 18, 2007 | 09:14 PM
RumbleFish's Avatar
srt>evo
Sorry....I have an SRT4 ...couldn't resist
Chris
http://www.piersdiesel.com/TechPyroInstall.htm
most seem to go toward the #6 cyl. supposedly it sees the hottest egt's.
Magnum Salvage
May 8, 2010 12:42 AM
bucknasty
Jun 15, 2009 11:58 AM
RattlerSkin
May 6, 2007 07:59 PM
tlhfirelion
22
Feb 21, 2007 10:49 AM
Palmetto_kid
Feb 24, 2004 05:13 PM
