need to no if 91 w250 rims will fit on my 89 w350?
Old Apr 25, 2011 | 11:05 AM
89_cumm1ns_w35o's Avatar
I found these 1991 w250 aftermaket used rims for sale and was wondering if the w250 has the same bolt pattern as my w350. they are both 8 lug. if anybody can help me out here that would be great.
thanks
Old Apr 25, 2011 | 11:19 AM
apwatson50's Avatar
is your w350 a dually?
If they are both single wheel trucks then they will fit.
Old Apr 25, 2011 | 11:57 AM
no its a single rear wheel, thanks
Old Apr 25, 2011 | 01:51 PM
They will work. Same wheel as what came stock on a 350 SRW
Old Apr 25, 2011 | 02:03 PM
gyman98's Avatar
They will fit although the aftermarket wheels are probably for 9/16 lugs, you have 1/2". If he has the 1/2" nuts to go with the wheels great if not you'll have to use your stock or special order lugs with the right degree. Or install 9/16 lugs
Old Apr 26, 2011 | 08:03 AM
SORTIE's Avatar
I am the seller of these rims, which are American Racing 12.5 x 16 with 33" mudders mounted on them.
The inner diameter of the rims (axle hole) is 5" and the mounting surface of the rim is 8"
8-bolt pattern and the buyer will get the custom lug nuts that came with these wheels. when I replaced them with OEM Dodge wheels, they bolted right up.
The wheels are in the DTR classified section and I put pics into my
photobucket account last night
I took a bunch of pics of the BACK of the wheels, and unfortunately those are the first pics on my photobucket page...it's obvious which side is the front vs back but READ THE CAPTIONS if there's any doubt.
the OP lives near me and subject to his review of these pics, we have a deal
Old Apr 26, 2011 | 09:54 AM
rebal's Avatar
you might have a rub issue with the 33 12.5 16 if you dont have at least a 2" lift on the truck I did with mine
Old Apr 26, 2011 | 11:09 AM
I think it depends on the backspacing of the rim.
And Sortie i think you're getting sizes mixxed up here.
The tires are gonna be 33 x 12.5 x 16.5
The wheels themselves are most likely 16.5 x 10" or 16.5 x 8' ?
The wheels are definely not 12.5" wide
Old Apr 26, 2011 | 01:51 PM
90 power ram's Avatar
i have 33 12.50 16 tires on my truck with the stock lift the rims were 8 in wide 12.50 is the foot print the tire has on the ground or how wide the tire is i wish i would have went with 33 10.50 16 so they would not rub pulling in my drive way under flex
Old Apr 26, 2011 | 09:06 PM
SORTIE's Avatar
you're right, son. I should never operate from memory at my age
NJTman
Apr 21, 2011 12:05 AM
jeepinaround
Sep 10, 2009 09:44 PM
Charger
Mar 6, 2009 06:51 PM
Hayseed
Dec 13, 2007 12:02 AM
Tommy93w350
Jan 25, 2005 05:29 PM
