Need the first gen fuel gurus to chime in!
Old Jan 20, 2018 | 12:01 PM
torquefan's Avatar
I'm thinking about how, on really cold days, little coolant and gasoline leaks always show up on vehicles, usually where a rubber hose is clamped or crimped to a steel line or fitting. And on radiators where the plastic tank is crimped to the core, and the rubber gasket shrinks. On a diesel truck's fuel system, it sure would be easy for a rubber fuel hose to shrink a bit on a cold day, where it's clamped to a steel line, and suck in a tiny bit of air. Pressurizing the fuel tank slightly and looking for leaks at all the connections might turn something up.
Old Jan 20, 2018 | 04:34 PM
peckens's Avatar
This year for me it has been Orings on the injection pump
Old Jan 20, 2018 | 07:48 PM
Torquefan might be on to something...
I have a'93 D-250 which starts hard in the cold and acts like it is fuel starved. I am guessing it is the fuel heater gasket /o-ring above the fuel filer that is going bad and doesn't like the cold. On warm days it starts great.
Or on cold days, once it has worked the air out of the line it runs great too.
I am picturing air is getting into the fuel system through the old dry gasket that doesn't like the cold. I have the new gasket on the shelf, I just need the time to install it and test my theory.
Old Jan 21, 2018 | 12:54 AM
ofcmarc's Avatar
Originally Posted by j_martin
You forgot it was 2 miles each way, and uphill both ways.
In all honesty, It was only about 1/2 mile and I lived on the flat part of the valley...
To the OP, I suppose an old, hardened fuel heater O-ring might shrink up enough in the cold to cause a problem but I would suspect you'd see a leak at other times there.
Old Jan 22, 2018 | 12:08 PM
patdaly's Avatar
Originally Posted by nascar mark
I know your saying it’s not gelling but as a Canadian, I see guys in the lower 48 on the different forums say the same problem ever year when it gets even a bit cold & even more this year due to it being even colder. Your fuel suppliers are either lazy or don’t have a clue or too cheap to cut the fuel to a “proper" #1 diesel when it gets cold.
How come in Canada when it gets -40F or even colder, you don’t see anyone saying they are having a fuel problem ? It gets -40F or even colder here and no problems. I don’t even have a fuel heater on my truck. Yes, very grumpy firing up when cold but that has nothing to do with no fuel heater, just the cold air, period.
Find another fuel supplier or start treating your fuel with 50% Kerosene. And no, pouring a bottle of what ever in your tank isn’t going to cut it, no matter what the label says !!!
Did you even read what I wrote?
Been in the diesel game for a long time now, and trust me, if I couldn't get properly treated fuel, I have been known to run straight #1, I have dosed them with gasoline and just about everything else that will burn.
The bottom line is, my fuel supplier has fuel that is correctly treated to the temperatures we face here, as do the suppliers in your area, and as I said, same fuel in both trucks, his didn't stay running, mine did, and all I had to do was bleed out the injectors and it started.
New lines are now in, and we are now waiting on the next cold snap, that will tell the story, if it shuts off again, then I need something to look at next, because my theory will be proven wrong.
Old Jan 22, 2018 | 12:54 PM
patdaly's Avatar
That's why I theorized the line thing. The original lines had deteriorated to the point where not only had we shortened and added rubber at the rear, but the boy had to take a couple feet out at the front when he changed the starter, simply bumping the line caused a rust flake to come off and start a leak.
I probably should have just run rubber all the way, but the price wasn't much different and this way I helped a neighbor Canadian worker out. ( Nova Scotia ).
Old Jan 22, 2018 | 12:55 PM
maybe368's Avatar
Looking at your sig, I have to say that 115 also keeps those wimps away, they are just different wimps...Mark
Old Jul 14, 2020 | 03:01 AM
OldBlueBC's Avatar
Solution
Any luck with the new lines ? I have had the same issue in Canada cold winters. I did recently drop the tank and replace the sending unit filter which was clogged solid. My next thought was the high pressure lines.
Dlowkes7
Jan 29, 2011 05:35 PM
Dubge
Jan 24, 2011 10:41 PM
Stovetop535
Jul 2, 2009 04:13 PM
pulltilbroke
Jan 24, 2008 07:34 PM
thumper 549
Feb 1, 2004 04:42 PM
