Need the first gen fuel gurus to chime in!
Ok, here is the story, the kids truck, the 89 lovingly dubbed the Mule has been acting like one recently.
Now get this, this ONLY happens when it is zero F or below, and the truck has been setting outside all night. Much above zero, truck runs flawlessly, truck taken out in below zero weather from a warm garage, runs flawlessly until it gets good and cold soaked. ( do not know how long that takes though )
What happens is depending on how cold below zero, truck will start, and the closer to zero it is, the further it will travel before slowing down and dying. When it was -22. wouldn't start at all, zero, you might make it a mile down the road.
The first time it happened, I figured a bad load of fuel, so we warmed it up,treated it, and bled out the injectors and she fired right up. Cool! next time, I added 5 gallons of #1 just knowing that would solve it. Wrong....... we were going to drain all the fuel and replace with known good fuel when the kid found out it wasn't gelled, because he bled the injectors while it was still outside and she fired right up.
So far, we thought there might be an issue with the fuel filter he had changed a month or so ago, ( saw some seeping at the top ) so we changed it again, good and sealed now, no change.
In my demented mind, i think there is a crack or something in the steel fuel lines that is only showing itself when it is cold enough to open it up, is that even possible? I do know the lines are original and we had to replace them at the tank because of some rust ( new longer rubber from tank to lines ) and he had to do the same at the front.
Anyway, I ordered a new set of exact fit lines from Rock Auto just to take that out of the equation.
Have any of you guys ever had something crazy like this?
mknittle (01-18-2018)
Pat I think your problem sounds just like a gelling issue. If your son was able to bleed out the nozzles that doesn't tell you for a fact it wasn't gelled at the time. That is often how gelling works, once the engine dies off the filter recovers and allows you to restart the engine as the blockage inside falls to the bottom.
I often take a small butane torch to the fuel filter itself while the engine is running if your surging clears up you know you have a gelling issue. This can usually get a piece of machinery inside the shop if you get the filter warm enough to maintain enough heat to run long enough to drive in.
The following 3 users liked this post by deere country:
My eyes just glazed over and I went into shock after seeing 0 and -22 degrees.
I know what I would do to fix this condition...move to Florida!
Had a few friends that broke their pull rope trying to get their sled started. My old John Deere Liquifire came to life with just three pulls but it was defiantly hard to pull over. It was 38 below zero that day and I beleive their was a low of 60 below zero somewhere in northern Minnesota. After the temp gets past 10 below to me it just all feels the same.
To me it's just like anything else weather wise you just have to prepare for it and know your limits. Just like staying in the shade when it's hot out in the summer. I enjoy the cold it keeps the riff raff out, well for the most part anyways.
I remember the governor calling off school for the entire state because of the cold weather once. We were thrilled as we went snowmobiling that day.
Sounds a whole lot like a gelling issue. If you are dealing with temps around 0* or colder, you have no business with #2 in your tank unless you only keep it in the heated garage and don't shut down until you get it back inside.
A piston LP will help a bit with the colder fuel but it wont stop gelling when the "Bomb-Cyclone" (or whatever meteorological term they want to invent and use that day) sends the temps way down.
Did I mention that there was 3' of snow too......
Guys, its not gelling, I wish it was that easy.
This has now went thru several tanks, including from the same supplier I use that has been the only thing starting down to -22F.
We are installing the new factory style lines tonight, the next cold snap will prove it one way or the other...............
How come in Canada when it gets -40F or even colder, you don’t see anyone saying they are having a fuel problem ? It gets -40F or even colder here and no problems. I don’t even have a fuel heater on my truck. Yes, very grumpy firing up when cold but that has nothing to do with no fuel heater, just the cold air, period.
Find another fuel supplier or start treating your fuel with 50% Kerosene. And no, pouring a bottle of what ever in your tank isn’t going to cut it, no matter what the label says !!!
The following 2 users liked this post by nascar mark:
edwinsmith (01-19-2018),
loudhornsrule (01-19-2018)
You know what is good about the cold? NOTHING!
End rant....
patdaly,
Does the truck idle ok in the cold temps? Will it die sitting in the driveway with the pump at half throttle in neutral?
If you want to rule out the fuel lines and fuel, simply run a hose from the lift pump to a bucket or a jug of known good treated diesel. See if the situation repeats. Changing lines isn't a hard job, but its not exactly fun. You could put a jug in the bed and take it for a ride with a rubber fuel hose zipped tied in the right places, but I didn't tell you that....
I have treated on road fuel with kerosene in a pinch when plow trucks started gelling, but those were old Formula 3 and Big Cam Cummins engines with mechanical pumps, that trick would probably kill these new snowflake diesels.
https://www.snopes.com/2018/01/16/ev...8-6-degrees-f/
You forgot it was 2 miles each way, and uphill both ways.
