need a couple torque specs for a few bolts on the rear end.
Old Mar 23, 2009 | 11:55 AM
Rick 12v CTD's Avatar
I need to torque specs for:
the 4 backing plate bolts
8 hub/axle bolts
wheels studs
wheel cylinder bolts.
axle retainer locknut - 120-140 ft lbs, backed off 120 degrees
I appreciate the help thanks guys!
Old Mar 23, 2009 | 12:32 PM
Richie O's Avatar
366 Spring Chicken
the 4 backing plate bolts 65 -105 ft lbs
8 hub/axle bolts 55 - 90 ft lbs
wheels studs Coned 175 - 225 ft lbs 5/8 x 18 300 - 350 ft lbs
wheel cylinder bolts. Book says 15 INCH POUNDS Thats not much
axle retainer locknut - As you said, 120 to 140 then back off 1/3rd turn
There you go.... Filled in your blanks. Had to get the book out. I just tighten stuff to what feels right.
Old Mar 23, 2009 | 12:34 PM
Richie O's Avatar
366 Spring Chicken
Im not sure why the book would give such a wide range of specs. Like the backing plate bolts. 65 to 105 is a pretty wide range.
Old Mar 23, 2009 | 02:07 PM
I agree, it seems a little weird but thanks a ton, I really appreciate it.
Time to go buy everything I need and put it all back together!
Old Mar 23, 2009 | 05:30 PM
'Cause it's not that critical. "Tight" is good enough.
Old Mar 23, 2009 | 05:43 PM
Richie O's Avatar
366 Spring Chicken
Thats what I do anyway. Don't get to worried about stuff unless its internal and I rarely get there.
mossyoak11
Feb 6, 2013 10:17 AM
roxxx
Dec 17, 2008 10:27 PM
daysel
Sep 13, 2006 03:59 AM
ratsun
Nov 10, 2005 09:42 PM
J-DUB
May 11, 2005 08:26 AM
