My project
Old Mar 20, 2012 | 01:15 AM
  #196
DJ Turbo.'s Avatar
Good to hear man!
Old Mar 20, 2012 | 11:55 PM
  #197
BILTIT's Avatar
Rear shocks are on the way!!!! Rear shaft should be done tomorrow too.
Just have to break in the clutch for a while and then add the dennyt pin, 3200 spring, turn up pump and get on it!!
Really curious to see what this thing will do.
Old Mar 21, 2012 | 09:28 AM
  #198
bryson711's Avatar
Glad to see your almost back on the road, its definitely been quite the project! Hey a question for ya, how hard was it to rebuild your 351? I have been trying to find a rebuild thread somewhere with no luck
Sent from my DROID2 using Tapatalk
Old Mar 21, 2012 | 09:37 AM
  #199
BILTIT's Avatar
It is easy to rebuild.
Here is the kit you need (its actually a HY35 rebuild kit):
http://www.dieselautopower.com/produ...%204031484.htm
If you can find a thread to rebuild a HX35 or the like it will be almost identicle.
Old Mar 21, 2012 | 09:48 AM
  #200
bryson711's Avatar
Awesome thanks for the help, I figured it would be pretty simple but I knew you had done yours so I figured I would ask
Old Mar 21, 2012 | 06:58 PM
  #201
BILTIT's Avatar
So my driveshaft is shortened but no one in town has a 1350/1410 conversion joint. I have a huge headache from trying to find one too. Found one company who is phoning tomorrow to see if he can get it (neapco is the only manufacturer that seems to make it).
I also ordered a fluidampr today.
I noticed it sure vibrates at idle alot more than i remember, not sure if its from the clutch or the new trans mounts, hence the fluidamper.
Old Mar 21, 2012 | 10:30 PM
  #202
SChandler's Avatar
What's the conversion u-joint for? Did the shop build the driveshaft with a 1350 yoke?
Old Mar 21, 2012 | 11:08 PM
  #203
BILTIT's Avatar
The Gear vendors only uses a 1350 yoke. I figured i would keep the shaft yoke original to save money, might have been better to have them put a 1350 on it too in hindsight.
Old Mar 21, 2012 | 11:39 PM
  #204
SChandler's Avatar
I didn't realize the Gear Vendors only used a 1350 output. Thanks for the info.
I'd like to take this opportunity to say thanks for being the guinea pig on the crossover steering setup for a 0-2" lift. It will certainly help out when I finally get around to lifting my truck in a couple of years (I'm planning on 2"-3").
Old Mar 22, 2012 | 07:40 AM
  #205
BILTIT's Avatar
No problem. Glad it will help other wise all that headache would be for nothing.
Old Mar 22, 2012 | 11:50 AM
  #206
jimbo486's Avatar
The output yoke is essentially off of a T-400 transmission. Another guy on here just put a new G56 and GV in his '92. Had troubles finding a 1410 yoke for it as well then heard why.
Maybe Gear Vendors should consider offering or making a larger output yoke for this reason. They'd have to know that more trucks are using their units. At least give them an option of using the larger output yoke for a 1410 joint.
Old Mar 22, 2012 | 02:14 PM
  #207
BILTIT's Avatar
Yup, you would think they would offer different sizes but i guess not.
So i have spent 3 days on the phone trying to find this u-joint in this city and have decided every parts person here is useless.
Only company i can find that makes it is Neapco P# 2-1435.
So now i will order it from the states since they have it in stock. Another week wait, you would think i would be use to this by now.......
Old Mar 29, 2012 | 05:56 PM
  #208
BILTIT's Avatar
Fluidamper just showed up ( wow, beefy unit) and u-joint should be here tomorrow so i should have it together this weekend sometime.
Old Mar 31, 2012 | 08:29 PM
  #209
BILTIT's Avatar
Finally got the driveshaft on and able to drive it. Everything is working well so far, put on about 50km picking up my campers and bringing them back into town. I do like this turbo so far, peppy! I have only seen 22psi max so far but i have been baby footing it for the clutches sake. GV makes a big difference, will do wonders for those long trips.
I have noticed it vibrates alot more at idle, assuming thats the DD clutch. Going to try and install the Fluidamper tomorrow.
I cannot wait to get this clutch broke in so i can install the fuel pin and turn the pump up!!!
Old Apr 6, 2012 | 06:02 PM
  #210
BILTIT's Avatar
Well im pretty happy with the new turbo so far. Unloaded WOT nets me 24PSI with stock pump settings, not too shabby. I can actually feel the power increase when the turbo lights up now, crazy. Sure makes the motor feel sluggish down low, might need to play with the AFC but i will wait until i put in the 3200 spring.
