Move timing and lost boost... is it bad?
Old Mar 11, 2010 | 11:44 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
I expected to lose a little boost but when i went from 1/8" advanced timing to 1/4" advanced it went from like 29-30psi to 25-26... seems like a lot. The truck sounds pretty good but i didnt really have a "set of the pants" feel to go by because my old pump wouldnt fuel WOT for more than a couple of seconds. I installed a piston pump and now i hold full boost.
I know boost is just resistance or whatever but i dont want to lose power if i dont have to.
Old Mar 11, 2010 | 11:45 PM
I dont know if my signature is working yet or not but here are my modifications....
92 W250(5qt Getrag)- Denny T, 8x.011" Injectors, 366 Spring, AFC Valet, 1/4" Timing, 4090 BHAF, Pump "Tuned", Piston Pump, Top-hat Ground, Boost/Pyro, Pull Cable.
Old Mar 11, 2010 | 11:57 PM
JQmile's Avatar
Nahh, you're fine. Less timing can create more energy out the exhaust, which will create more boost, while more timing might create less boost, but more cylinder pressure, and hence, more power. Boost does seem a little low with your mods though. How far is the fuel screw turned in?
Old Mar 12, 2010 | 11:11 AM
its all of the way in. i still have a stock h1c turbo and exhaust. my smoke screw is way out and my starwheel is up 8 turns but when i tried it all of the way down it made the same boost.
Old Mar 13, 2010 | 01:08 AM
I don't really know if its relative but on the highway (4th gear and wide open throttle) i can get up to 1300+ degrees so im assuming im getting plenty of fuel. Im pretty intrigued about how much lower my boost is now... 5 psi for 1/8 timing seems like a lot and i want to know if the added timing is hurting me.
Old Mar 13, 2010 | 01:27 AM
W150CTDproject's Avatar
time for a bigger turbo, you have plenty of fuel
Old Mar 13, 2010 | 01:29 AM
oh yeah i know its turbo time haha... i need exhaust too but i have very little money (very little)
Old Mar 13, 2010 | 01:41 AM
you and me both lol. for my turbo i bought a shelled HX35 for $100 from a friend. t crapped the exhaust wheel out the housing with some fin stuck/melted to it, so i took the 35's compressor housing and my stock H1C (non i/c engine in my 92 so it had the lil guy) put it the 35's compressor on. so i have a 54mm (i think) inducer and a 18cm housing. works quite well. Check Ebay for turbos, craigslist, classified on here or the cummins forum, scrap yards, possibly friends. just a few places that you might want to try. You never know what you find
With 3" intercooler piping, 24 valve intercooler and intake horn i push 30 psi
Old Mar 13, 2010 | 01:50 AM
i dont know what i would push with stock timing... 1/8" it was 30 psi with the stock fuel pump (i know i said this already) so im going to say it would be like 33 with the stock timing.
i just made a new buddy who has a buddy with turbos laying around so i might check that out and see what he's got. i check craigslist and stuff a lot but people want 300 bucks for the stock junker i have now lol. i know turbos are cool but the prices can be WAY out of the park.
Old Mar 13, 2010 | 02:19 AM
oh yeah..i forget too much... i have a 21 cm exhaust housing so its a not exactly a fast spooler.
Old Mar 13, 2010 | 07:22 AM
Mike T.'s Avatar
With my timing marks lined up I'm at 34psi, 1/8 bump was 31-32psi
Bryan026
Apr 11, 2011 11:43 AM
Tron
Sep 9, 2007 08:37 AM
pwrtripls1
Jun 6, 2005 11:34 PM
ClawHammer
Aug 7, 2004 08:49 AM
wannadiesel
Oct 12, 2003 07:51 PM
