modulator leak on inj pump 92 model?
Old Apr 9, 2011 | 02:43 PM
leper's Avatar
Can the modulator valve be resealed? I have looked all over and don't see a breakdown for just the valve. Mine is leaking the the leading edge. It looks like I could just unscrew the bolt in the end, but I don't want to take it apart to realize I just ruined it.
I have looked through the sticky.
Old Apr 10, 2011 | 09:16 AM
leper's Avatar
Any ideas?
Old Apr 10, 2011 | 05:24 PM
jimbo486's Avatar
Uhhh, modulator valve? Got a picture you can post?
Old Apr 10, 2011 | 05:58 PM
leper's Avatar
https://www.dieseltruckresource.com/...d.php?t=231863
Third picture down, part 37,pressure modulation valve.
Old Apr 10, 2011 | 07:34 PM
jimbo486's Avatar
Looks like the KSB to me. There's one o-ring behind it. Remove the 2 torx bolts and the hard line coming into the top of it and replace the o-ring. The torx bolts are kinda tight and can give you a hard time when trying to remove them. They're prone to stripping out so you'll have to be extra cautious that the bit is in the head straight. I used a small pick to get any debris out of the bolt head to allow the bit to sit as deep as possible. Also, I'd suggest pulling the vacuum/powersteering pump to give you additional room 'cause it will become an interference with whatever tool you decide to use to remove the bolts. Unplug the oil pressure sensor, otherwise the pump can't move.
Old Apr 11, 2011 | 10:05 AM
leper's Avatar
KSB it is. Its been a while since I messed with this truck. The leak isnt coming from the back side, I replaced that gasket when I had it out the last time. It is leaking from the leading edge, where the exposed hex head is, pointing at the front of the truck.
Thanks for your info.
Old Apr 11, 2011 | 07:38 PM
jimbo486's Avatar
You should be able to just pull that plug and replace the o-ring. Just keep a catch pan ready in case there are any shims and a spring behind it.
hotwrench4hire
May 14, 2013 06:48 PM
bannerd
Sep 6, 2012 10:03 AM
RedRam410
Feb 2, 2007 10:27 AM
9 sec camaro
20
Aug 26, 2006 01:30 PM
chevummins
Sep 30, 2004 03:37 AM
