Missing bolt
Old Sep 30, 2005 | 12:22 PM
92DIESEL's Avatar
Exclamation Missing bolt
I finally have a chance to change my radiator, and while doing so found that one of the timing cover bolts is missing It is the one dierctly under the fan hub assembly. I went to the store and got a new one.
My question is before I put it all back together is there anything that I should do?
I still have not been able to locate my oil leak in the front, I just degreased the front of the engine again.
I'm going back out now, so if you could think of anything let me know.
Thanks,
Michael
Old Sep 30, 2005 | 12:25 PM
67HotRod's Avatar
Look hard at the gasket that is between the block and the case the cover attaches to. If its leaking, plenty of work getting that one replaced...
Old Sep 30, 2005 | 12:39 PM
92DIESEL's Avatar
I don't see any oil coming from there... it looks more like under the alt. but above the A/C. But I don't know...
can I start the engine without the belt and fan on for a minute or so to see if I can find it?
Old Sep 30, 2005 | 12:42 PM
apwatson50's Avatar
It'll probably idle all day with out the fan belt and fan. Are you going to have the radiator hooked up and filled? The only thing is that the water pump won't be pumping. But seriously there shouldn't be any problems for a few minutes just don't let it get too hot.
Old Sep 30, 2005 | 12:50 PM
92DIESEL's Avatar
I was hoping to do it without the radiator in... literally one minute, I don't think it will get hou that quick.
Old Sep 30, 2005 | 01:00 PM
67HotRod's Avatar
1 to 2 minutes won't hurt, having someone help start and shut it down helps.
Old Sep 30, 2005 | 01:04 PM
92DIESEL's Avatar
Thanks I'm going out now to try. Wish me luck.
Old Sep 30, 2005 | 04:22 PM
ChrisLib's Avatar
When i changed the front crank seal on my truck I found several of the front cover bolts loose, in fact half of the oil leaking was probably just coming from the darned cover. Whe i reassembeled it I used some Permatex Aviation sealnt on the bolt threads, it should help keep them from vibrating loose but still be able to take it apart in the future.
Old Sep 30, 2005 | 06:25 PM
92DIESEL's Avatar
I tried putting in the new bolt and guess what... the old one is broken inside the cover.
I put everything back together, no other loose/missing bolts, and I don't see a leak
I hope it holds up ok.
Michael
TallTom
May 1, 2007 01:55 PM
Brendan
Dec 26, 2006 11:31 PM
Ramtough
Jun 2, 2006 11:28 AM
2500CTD
Aug 9, 2005 06:04 PM
5HRacer
Dec 17, 2004 06:21 PM
