Metal sockets on throttle linkage
Old Mar 2, 2011 | 05:06 PM
jimbo486's Avatar
Cool Metal sockets on throttle linkage
I purchased the new control rod kit with new metal rod-ends and threaded rod a couple weeks ago. I finally installed it on Monday this week. I took a jewelers file to part of the breakover spring because when the rod-end rolled towards the engine, it would catch on the little "leg" of the spring. The file didn't remove much material but enough to make clearance for free movement.
Along with the new control rod, I also replaced my AFC top screws with new stainless hardware that I picked up from Fastenal. Grade A2 - M6 - 1.0 x 14mm socket cap screws with Grade A4 - M6 flat washers. Now I can use a "T" handle alan wrench and easily remove the screws for starwheel adjustments or fuel pin changes. The screws were $0.25 each and the washers were $0.16 for a total of $1.79. If I had ordered from their website, I would've been charged $7 shipping . A little ridiculous for 4 bolts and washers . I called Fastenal and made my point about the shipping cost and asked if they could order them for me and put them on will call. They gladly did so and I picked them up and installed them this morning. If only I had painted my AFC top to clean it up, things would look a lot better! Oh, and I finally removed the protective cap on my smoke screw. I adjusted it out about .050" which should be just enough to center the AFC pin between the bottom of the fuel pin and start of the profile on the M3.
Old Mar 2, 2011 | 06:55 PM
nice. but put the smoke screw cap back on and draw a smiley on it like i did
Old Mar 2, 2011 | 07:34 PM
jimbo486's Avatar
The cap is destroyed! I took a spring loaded punch to it and made a couple holes in it. Then used needle-nosed pliers to twist it out.
Old Mar 2, 2011 | 07:36 PM
KD93's Avatar
I just need a slim flat head screwdriver to ease mine out.
Old Mar 2, 2011 | 11:25 PM
gadget.35-06's Avatar
Wish I'd been able to find throttle linkage parts easily when I needed 'em...I had to fabricate 'em from Napa loose parts.
Old Mar 7, 2011 | 08:42 PM
hounddogks76's Avatar
I called cummins today....and he had to call the factory to source them..but he found some. Cost is gonna be 36.00.
Old Mar 7, 2011 | 08:46 PM
92smokin blacky's Avatar
I bought just the ends last week. Got them from my local tractor/implement dealer and they ordered the cummins parts in for me. It was just over $8 each, he first quoted me $12 each but then later he quoted $8, not sure what happened.
Old Mar 7, 2011 | 08:53 PM
james1's Avatar
I bought my new throttle control rod as an entire unit from Cummins but the ends are plastic.
Old Mar 8, 2011 | 02:55 PM
bgilbert's Avatar
Jim looks like your breakover spring is about wore through.
Old Mar 8, 2011 | 10:35 PM
jimbo486's Avatar
It looks like it is but it's all still there. I have a piece of short length of 1/8" stainless tubing cut into a half-round to make up for the small movement before the throttle control lever moves, due to the small notch in the pin that comes up through the middle of the breakover spring's legs. Here's a better look at it...
I replaced my original breakover spring shortly after I got the truck about 2 years ago. It was definitely worn through. So much so that the leg snapped off while trying to remove it.
92smokin blacky
Apr 28, 2011 02:53 PM
mattmanj2001
Aug 19, 2010 08:18 PM
mhuppertz
Feb 23, 2010 08:34 AM
bob95065
13
Feb 25, 2009 11:28 AM
DISLSMOKE
Sep 28, 2006 07:40 PM
