Mc Mobile
Old Jul 29, 2009 | 08:39 PM
  #91
Yea with the way that is now, your sucking hot air from the exhaust manifold and from the alternator :nono: not good at all.
Put a 45 on it and some pipe, clamp the filter on the end, maybe bring it out so the back of the filter is like at the alternator??
Old Jul 29, 2009 | 08:41 PM
  #92
That's not you engine bay is it?? i don't remember you painting the firewall green and it has one of them funky inline inj. pumps on it.
Old Jul 29, 2009 | 08:59 PM
  #93
BearKiller's Avatar
Originally Posted by Mike Mc
How do you guys feel about this filter set up?
I ran my Ford/Cummins just like that for probably a year before I spent a bunch of money and plumbed in a filter-box.
I expected towing EGT to dramatically decrease, but I can't see it on the PYRO.
It sure sounded a lot better when the filter was clamped straight on the turbo.
On his Ford/Cummins, my cousin had a plumbing boot slip from under the clamp and suck through the turbo, costing him an engine, along with a small engine fire that scorched the hood pretty bad; he has ever since been running the filter just like you have pictured.
Old Jul 29, 2009 | 09:14 PM
  #94
Mike Mc's Avatar
BK, he must not of had a after cooler to trap the turbo debris after it granaded?
I already have a big tractor fresh air box mounted. But I like all the turbo whistle
No it's a pic of my buddies truck.
Old Jul 30, 2009 | 01:28 PM
  #95
Mike Mc's Avatar
Can I shorten the pyrometer wires if I cut them at the same length?
Old Jul 30, 2009 | 02:02 PM
  #96
Ace's Avatar
Ace
Nooooo, don't do that. They are calibrated to be that length.
Old Jul 30, 2009 | 07:47 PM
  #97
DWitcher's Avatar
Cool truck. What part of town are you in.
Old Jul 30, 2009 | 09:59 PM
  #98
Mike Mc's Avatar
Thanks DW, I'm way out in Rosedale.
Old Jul 31, 2009 | 02:33 PM
  #99
Mike Mc's Avatar
This Jacobs/Cummins exhaust brake has two different size flanges, one is thick and flared out and the other thin and flared in . The V-clamp only fits the thinner flange. It looks like this is meant to fit directly on the turbo. I don't have enough room between the turbo and firewall to mount it. So I was going to mount it down stream were there is pletty of room.
Also, someone told me I need stiffer exhaust valve springs or they need washers stacked to make them stiffer?
Right now I'm tired of messing with it and thinking about just leaving the E. brake off.
Any suggestions on the clamp and valve springs?
Old Jul 31, 2009 | 05:32 PM
  #100
You need 60 psi exhaust valve springs or you will float the valves at high RPM.
If you're going to put it inline then get some flanges to weld in along with some clamps. Try these guys: http://www.airflo.com/
Old Jul 31, 2009 | 07:47 PM
  #101
Mike Mc's Avatar
WD. will floating valves hit the pistons?
If I pull a valve cover can I tell what pound the springs are?
  #102
BearKiller's Avatar
What is the inside-diameter of that brake ??
Thanks.
Old Jul 31, 2009 | 10:06 PM
  #103
Yes, they will hit the pistons. That's how you change springs on these motors, bring the cylinder to TDC and let the valve sit on the piston while you change the spring.
If the exhaust springs are obviously thicker than the intake springs then they have been upgraded.
Old Jul 31, 2009 | 10:19 PM
  #104
DWitcher's Avatar
Kick EDIT. I'm way out off Olive Dr.
Old Aug 1, 2009 | 12:11 PM
  #105
Mike Mc's Avatar
BK, the exhaust brake has a 2-9/16 I.D.
