Mc Mobile
Old Aug 1, 2009 | 03:02 PM
  #106
BearKiller's Avatar
Originally Posted by Mike Mc
BK, the exhaust brake has a 2-9/16 I.D.
Thank you.
Old Aug 1, 2009 | 11:14 PM
  #107
Mike Mc's Avatar
The '05 F350 cooling system has a pressurized overflow tank that circulates the coolant. I need to tap into one of the Cummins heater lines that run inside the cab. Witch one of these two lines is the pressure line?
Or is there a better pressurized spot for me to tap into?
Old Aug 2, 2009 | 12:01 AM
  #108
Mike Mc's Avatar
One more question for the board.
Will this work on my '93?
http://cgi.ebay.com/ebaymotors/02-Do...ayphotohosting
ad removed
Old Aug 2, 2009 | 06:57 AM
  #109
It will clamp to your turbo like it grew there. As long as the angle does not cause you any trouble it will work fine.
Old Aug 2, 2009 | 12:39 PM
  #110
Ah shoot thats the elbow I need! sweet.
Old Aug 3, 2009 | 09:35 AM
  #111
Mike Mc's Avatar
WD, not trying to stump you by asking two questions, but you got any ideas on this?
The '05 F350 cooling system has a pressurized overflow tank that circulates the coolant. I need to tap into one of the Cummins heater lines that run inside the cab. Which one of these two lines is the pressure line?
My Ford pick up has a small coolant hose coming from the top of the engine to the top of the coolant tank. I'm not sure if this little hose is on the pump side so it circulates the coolant in the tank or just allows the tank to breath. Anybody point me in the right direction on hooking up this coolant tank?
Old Aug 3, 2009 | 06:18 PM
  #112
It is a circulating hose. The big fitting on the bottom of the tank should tee into the heater hose that comes off the back of the water pump, the little hose should tee off the heater hose that comes off the side of the block just below the head.
Old Aug 7, 2009 | 12:31 AM
  #113
Mike Mc's Avatar
Thanks for the info WD. Almost got it all plumbed.
I'm wiring up a manual switch and a temperature switch to automatically turn the electric fan on at a certain temp. I'm guessing the auto temp switch should be about 10 deg. hotter than the thermostat. What auto temp switch deg. is recommended?
Old Aug 7, 2009 | 05:05 PM
  #114
I think on at 200, off at 190 would work pretty well.
Old Aug 11, 2009 | 09:42 PM
  #115
Mike Mc's Avatar
Got to run the 5.9 today for about 2hrs . The little electric fan and Ford radiator easily kept the temp. at 180. Shut the fan off and the temp would slowly climb up. Turn the fan on and right back down to 180.
I've been wanting dual exhaust and being the McMobile....... I ran two 4" stacks on one side ...... little easier installation too.
Old Aug 14, 2009 | 09:28 AM
  #116
Mike Mc's Avatar
Still pecking away.... kinda hard to reach the hood
Here is a pic of my 5' 10" helper standing in front.
Now I need to start on the doors, got all new rubber and felt kit.
Old Aug 14, 2009 | 09:36 AM
  #117
apwatson50's Avatar
Um I think someone needs a ladder.
Old Aug 16, 2009 | 10:52 AM
  #118
Mike Mc's Avatar
Got to drive the McMobile up and down the back roads yesterday Been along time since driven.
But before I put the rear drive line in I checked the Brownie Box O.D. gear ratio. I marked both input and output shafts, turning the input one revolution the output turns 1.4 rev.
What O.D. gear ratio would that be? .60?
Old Aug 16, 2009 | 11:16 AM
  #119
0.71:1
Old Aug 16, 2009 | 11:21 AM
  #120
Trooperthorn's Avatar
1:1.4 is aproximately equal to .71:1
