Manual automatic?
Old Oct 21, 2009 | 01:02 AM
MBolivar's Avatar
Manual automatic?
Anyone running a manual valve body and how do you like it? After reading the posts about early shifting, seems like a manual valve body would be nice on a play only truck. I don't know how the u-joints will like that. I am running a Suncoast valve body with the TV cable as far as it will go and it still shifts early and of course, the 366 spring only worsens it. I am ordering a new converter and that will again change the shift points, right?
Old Oct 21, 2009 | 03:12 AM
NO_SPRK's Avatar
this is a little off topic but ive heard of old drag racers running clutches infront of their automatic. crazy hard shifts
Old Oct 21, 2009 | 10:13 AM
unixcowboy's Avatar
Same problem, different solution......
I bent a Z into the part of the TV cable that attaches to the throttle linkage.
Then I adjusted the Z shape until the tranny shifted where I wanted it to at WOT - ~ 3200 - 3300 rpm.
I just live with the early shifting at light or part throttle.
OR I manually shift it
Old Oct 21, 2009 | 10:54 PM
schamran's Avatar
Yeah, you shouldn't need a manual valve body. Only to keep it from shifting down right?
Old Oct 21, 2009 | 11:02 PM
Riflemanusmc's Avatar
Registered user
That would be the cluchflite. Banging gears with one of those breaks parts, so I hear..........
Old Oct 21, 2009 | 11:17 PM
MBolivar's Avatar
Cowboy, you got any pics?
Old Oct 22, 2009 | 05:45 AM
jughead's Avatar
got a manual in my 82. lot of fun. got enough power that in normal driving only use high gear. only ones i have ever used would not hold back in low gear. could be a problem if one towed. over the years my son and i have probably put 130-140k on various chry vehicles with manual valve bodies with no problems
Old Oct 22, 2009 | 12:02 PM
unixcowboy's Avatar
Thought I did, but not...
When it stops raining I'll get a couple
Old Oct 22, 2009 | 02:29 PM
unixcowboy's Avatar
Couldn't get real good focus on the Z'd portion but you can see where it's bent and get an idea.
Right now it's 47* and a lite drizzle.
When ( IF ) it clears a little, I'll try my macro lens and see if I can add a closeup of just the Z'd part.
Old Oct 22, 2009 | 10:55 PM
MBolivar's Avatar
Thanks for posting that pic. I'm wondering if I should put the throttle linkage back to the original outside hole on the lever. Wouldn't that change the travel geometry of the TV cable also? I read some users have put a small bolt in the TV cable slot to close up that small gap so the throttle bell crank pushes it sooner.
Old Oct 23, 2009 | 10:03 AM
unixcowboy's Avatar
When I installed my 3200 gov spring I checked the total travel of the throttle lever inside the top.
I had been reading about the idle going up after the install and reasoned that the spring was pulling the gov more than the stock spring - so -
I adjusted the throttle lever so it was pointing straight at the gov attachment - you know, that pesky top hat that everyone drops
Then I watched the hash marks on the outside so I knew where to set the lever for min, and how far it would rotate for max.
I adjusted my linkage so I had full travel which made me back off the high idle screw completely and the low idle only has 1 or 2 threads showing.
When I still couldn't get full travel with the linkage adjustment I started 'modifying' the cable connection to the pedal. The throttle cable pivot has a piece of metal underneath that stops the pivot from going very far. After I removed that, I had ~ 1/2" more travel.....
All those changes made the TV move waaayyyy too soon and waayyy too far - even with it as far out as it would go - the opposite end to normal adjustment...Full throttle would never shift until you let off a little and then it would slam into the next gear. NOT a good idea.
So I bent the tv rod and played with the cable adjustment until I got it to shift at ~ 3200 - 3300 rpm through the gears.
Throttle on the floor and I lock out OD and get 1 - 2 shift ~ 30 - 32 mph and 2 - 3 ~ just under 60 mph then I hit the OD at ~ 80 mph....
CACalomino
16
May 18, 2005 09:27 PM
Palmetto_kid
Jun 28, 2004 07:14 AM
antknee
Aug 4, 2003 10:10 PM
azjeff
Jun 24, 2003 07:19 PM
engcogod
16
Oct 29, 2002 07:28 PM
