Main/Rods with engine in chassis?
Old Feb 16, 2005 | 05:59 PM
TomJ's Avatar
Anyone done this or know if the main/rod bearings can be refreshed with the engine in the chassis, or is that a pull?
Old Feb 16, 2005 | 06:37 PM
Monty did his a couple months ago when he changed the thrust bearing. As long as the crank is OK there's nothing wrong with doing it in the truck.
Old Feb 16, 2005 | 06:56 PM
Monty's Avatar
Search for the thread "Just My Luck" in this forum. I believe that was the thread name that I posted to when I did mine.
Old Feb 16, 2005 | 08:27 PM
Mudcat's Avatar
I am wondering how this would go with a 4x4? Anyone have any idea if it would be easier, harder or similar? I haven't looked under a 2wd very much.
By the way here is a link to the thread. Just my luck
Old Feb 16, 2005 | 09:48 PM
Flake's Avatar
It wasn't too hard to do in my 4x, but I was also replacing motor mounts at the same time so I loosened them first. It might be too tight without loosening the MM to get the pan between the crossmember and the block.
Old Feb 17, 2005 | 09:55 AM
SmokinFive9 4x4's Avatar
Been there done that. It was a pain getting the pan off, because of the crossmember going under it, but once that's done it's not so bad. G'luck
Old Feb 17, 2005 | 01:27 PM
TomJ's Avatar
So I assume I can unbolt the motor mounts and lift the engine till the bellhousing hits the cab and probably get the pan off WITHOUT removing the tranny?
Old Feb 17, 2005 | 03:39 PM
Hemi Cat's Avatar
That will be close. Sometimes removing the cab bolts and raising the cab will allow you to raise the motor a little more and the pan comes out easier. You shouldn't have to remove the trans unless you need to replace the rear main seal. Good luck.
DieselRV
Competition / Pulls / OffRoad
0
Jul 16, 2013 03:43 PM
DodgeDiesel61
Sep 17, 2012 11:37 AM
fivecents3
Apr 15, 2006 06:07 AM
TIMMY22
Nov 23, 2005 12:22 PM
marvm
Mar 28, 2003 06:24 AM
