Lug nut question.......thoughts?
Old Jun 5, 2010 | 09:44 PM
4xfourfun's Avatar
Well, the previous owner of my truck didn't take much care of the aluminum wheels, much less the center caps and lugs. I'm going to remove the wheels and mount different tires. I figure that will be a great time to polish the wheels.
As far as the center caps and lugs, I don't think they can be saved! I'm thinking my 92 W250 CTD has 9/16" lugs, am I thinking correctly? Does anyone have any recommendations on lugs? I like the looks of the longer ones, like 2" or more. I was searching around and even see some that are splined now. Ever hear of a brand called Gorilla? A couple trucks ago I had McGard lugs that were great, but that was pretty expensive for 32 of them! I'll just have to try and find a decent set of cener caps(not cheapies) and keep them polished hoping they don't rust too easily.
Thanks for any input in advance.
Old Jun 5, 2010 | 11:25 PM
schamran's Avatar
A STOCK first gen single wheel has 1/2" studs. A dually has 5/8" studs. However, a single wheel can easily be converted to 9/16" studs. If you buy different lugs i suggest that you get something that is difficult to steal.
Old Jun 16, 2010 | 07:39 PM
85crewcabbie's Avatar
Schamran is correct on the lug sizes on both counts. your lugs are definitely not 9/16 unless someone changed them.
Old Jun 16, 2010 | 07:52 PM
JBradley500's Avatar
From: A 5th dimension, beyond that which is known to man.
note--- dont buy the 99 cent ones from advanced auto or where ever. mine are 6 months old and look like poo
Old Jun 19, 2010 | 01:10 AM
One of the PO of my crew converted the rear to 9/16 studs, to run the 2nd gen lug nuts for the center caps. So I have 1/2" of the front and 9/16 on the rear....
wisconative
May 13, 2013 07:20 AM
dieselJon
Mar 6, 2008 04:58 PM
MTC
Feb 6, 2007 02:07 PM
Trebor
Sep 14, 2006 04:52 PM
Boz007
Mar 28, 2006 07:39 PM
