Lower control arm BROKE!!!!
Old Mar 16, 2005 | 09:20 AM
spunbearing's Avatar
The spring probably tweaked when the truck hit the ground. A new set of 7226s springs will fix that right up and it will probably sit better in the front. My new springs gave me 2 inches of lift originally and it settled about 1/4 inch in 3 weeks.
Old Mar 16, 2005 | 11:11 AM
chevummins's Avatar
Discontinued part
I called all the junk yard and no one has the control arm. Dodge dealer says it was a discontinued part. What do I do now? Anyone have a parts truck? Should I weld it back up, competently of course with addition structure to support the weak area? Thanks for your time and those new springs might be nice....
-Greg
Old Mar 16, 2005 | 02:50 PM
http://www.car-part.com/
It appears from a quick search that '91 is a hard year to deal with, gotta know the build date on the truck.
Old Mar 16, 2005 | 03:58 PM
Rammer64's Avatar
Re: Discontinued part
-Greg
"DEFINITELY NOOOOOOO!!!!!!!! Do not weld.
You said you were lucky it only broke backing out of the driveway and not doing 60mph on the highway. Why would you think of trying to give bad fate a second chance?
A good welder can weld it back together, but the heating process will only create another heat/stress point farther back next to the new welds.
You would be living a life of chance. My choice would be "ABSOLUTELY NOT"
May not be the answer you want to hear, but that's JMHO.....
Old Mar 16, 2005 | 08:28 PM
2500CTD's Avatar
try all u pull iguess. I usually dont have good luck with the pre pulled part yards. Plus I like doing the work meself! Keep us posted. What abot a Van LC??? Take somemeasurements, maybe. Ya never know what Mopar did to save some tooling costs.
Old Mar 17, 2005 | 09:33 AM
<-------- wondering if the 1 ton motorhome control arms are the same????
Old Mar 17, 2005 | 09:50 AM
chevummins's Avatar
junk yard dog
I had a reply from a yard in AZ off of the junkyard dog .com $45 for the arm and $15 shipping sounds good to me. I don't think that I would really weld on it... it was just a passing thought. Thanks for the advice. Also the dealer told me the arms for vans and 1 tons were different. I think I will buy the arm and fix it but only plan on driving another 6 mos or so before I start into the chevy repower with this truck as a donor. What do you think....?
Old Mar 17, 2005 | 02:48 PM
Jim Lane's Avatar
Question Control Arm
Has anybody checked the companies that build off road trucks, Seems that they must use something stronger than the stock units. Most that I have seen have them built out of moly tube with lots of support. And they really thrash their trucks
Old Mar 17, 2005 | 03:22 PM
Smokee's Avatar
I had an 89 break in the same place. In that year, you could cross from almost any model.
rammv
0
Jun 28, 2014 04:04 PM
feets
Jul 31, 2007 07:24 AM
Geets
18
Dec 19, 2006 10:57 PM
Geets
Dec 19, 2006 11:49 AM
PWT05Dodge
May 26, 2006 06:45 PM
