Lower Control Arm Removal
Old Dec 18, 2006 | 09:56 PM
Geets's Avatar
I'm in the process of installing a 4.5" Tuff Country lift on my 03' 3500. I'm at the step where I'm supposed to remove the lower control arm. I was able to remove the rear nut and bolt on the arm. On the front of the lower control arm where it attaches to the front axle I was able to remove the nut only. Is there something special that I have to do to remove the bolt holding the control arm? I can't turn the bolt either, is there a special tool that I need to push the bolt through to the other side? Please help, can't do anything else until I get past this point.
Thanks much.
Old Dec 19, 2006 | 09:41 AM
Howy's Avatar
A big hammer? That would be my guess. Never had that problem with control arms before.
Old Dec 19, 2006 | 10:56 AM
Scramblinman's Avatar
Thread the nut back on and give it a few good whacks with the big hammer. That's what it took to free up those link arm bolts on my truck.
Old Dec 19, 2006 | 11:49 AM
roysleight's Avatar
Mine were so frozen I ended up cutting them off with a torch and buying new bolts and rubbers. Hopefully you don't need to do that.
feets
Jul 31, 2007 07:24 AM
Geets
18
Dec 19, 2006 10:57 PM
PWT05Dodge
May 26, 2006 06:45 PM
chevummins
Mar 17, 2005 03:22 PM
