Loud Squeal!!!!!!!!
Old Jun 23, 2007 | 01:39 PM
65fury's Avatar
Loud Squeal!!!!!!!!
my buddys 1991 2wd ctd with 727 auto, and on are way back from utah out of the the blue this loud squealing (sounded like air being let out of a baloon) started sounding and the pitch increased with how hard i pushed the peddle, the noise only sounded when the truck was under load and at hard throttle, like when we hit hills, i came from the driverside, im thinking its a tiny vaccum leak but don't know, anyone have any ideas??? thanks
jason
Old Jun 23, 2007 | 02:23 PM
BC847's Avatar
1st Generation Admin
Jason it sounds a lot like you may have found a small hole in one of the intercooler boots.
Check them closely especially around the drivers side as it seems the trans cooler line clamps may worry a hole on occasion if they get close enough. Make sure all the hose clamps have at least a quarter of an inch of hose sticking out past them to clamp good.
Stuff like that. The intercooler itself is suspect as well.
Hope this helps.
David
Old Jun 23, 2007 | 03:12 PM
Cowboy_Customs's Avatar
intercooling system. Mine did the same thing, when I wrapped the hole in duct tape, n blew a hole through that. Check yer boots.
Old Jun 23, 2007 | 03:21 PM
65fury's Avatar
ooops i didn't specify, my bad, its my buddys truck, but it is the non ic model, so with that do yall have any other ideas, there isn't any difference in how it runs at all, it just squeals underload or harder acceleration between 40mph and up, but if you slowly accel up to highway speeds it wont squeal.
jason
Old Jun 23, 2007 | 03:49 PM
Like everybody else said, you most likely have a boost leak. An exhaust leak before the turbo can also cause a squeal.
Old Jun 23, 2007 | 06:01 PM
65fury's Avatar
well i guess this weekend my buddy and i will check all seals and tighten everything to be sure thanks
jason
Old Jun 24, 2007 | 10:31 PM
thewished's Avatar
Mine had a squeal but it was the middle u-joint on my driveline...
Old Jun 25, 2007 | 10:28 AM
spunbearing's Avatar
Wouldn't hurt to replace the serpentine belt. Mine had a nasty squeal under load.
Old Jun 25, 2007 | 11:49 AM
G1625S's Avatar
Check the little steel line that feeds the AFC housing boost from the intake. I played with my timing one too many times and that line cracked. I chased that whistle for a week
Old Jun 25, 2007 | 12:25 PM
JDGnut's Avatar
Also check the belt tensioner.. The idler bearing some times get noisey...
madmax44
Jun 17, 2009 02:18 AM
SimonRV
Aug 5, 2006 09:30 PM
Kuntry
Aug 30, 2005 12:57 AM
crossy
16
Aug 26, 2005 06:03 PM
CTD99
Dec 11, 2003 09:17 AM
