Little red light....go away
Old Feb 19, 2007 | 11:15 PM
stoneage's Avatar
Question Little red light....go away
After preforming the external VR mod, is there any way to get the check engine light to go away? The code is 41 Generator field not switching properly. Any suggestions?
Old Feb 19, 2007 | 11:46 PM
BearKiller's Avatar
Two ways.
Easy = stick black tape over the light
Not as easy = find wire to light and clip
Old Feb 20, 2007 | 12:07 AM
woodrat's Avatar
Maybe that's all you can do. My FSM says the light will go off once you have corrected the fault code. Sounds like your computer will now forever think that there is a fault...
Old Feb 20, 2007 | 11:15 AM
ppiggppenn's Avatar
is there no code reader to D/L and clear codes on these? I can read my codes with that ignition on-off-on-off-on thing in the manual but I don't recall a procedure to clear codes other than fixing whatever caused it. Some can be cleared by lifting a battery post and running lights etc to drain any capacitors, but don't know if that'll work on our 1st gens. What's a VR?
Old Feb 20, 2007 | 12:59 PM
12valve@heart's Avatar
Originally Posted by ppiggppenn
What's a VR?
Voltage Regulator
Old Feb 20, 2007 | 07:42 PM
dpuckett's Avatar
As far as I know, you are stuck with it.
Option 3- remove bulb from dash assembly. I hate to cut wire if I dont have to. What else would the "check engine" light feed to?
Daniel
Old Feb 21, 2007 | 09:34 AM
ppiggppenn's Avatar
<After preforming the external VR mod> ...can you do without the mod? I'd hate for the light not to work in case something else threw a code I needed to know about. Just a thought
Old Feb 21, 2007 | 05:01 PM
There really aren't many useful codes out of our PCMs. They don't really do anything that critical.
TRX24V
Oct 29, 2007 12:44 PM
Efretwell
Nov 16, 2006 01:58 PM
bkrukow
15
Aug 29, 2006 06:41 AM
mt72916
Feb 1, 2005 08:00 AM
msthomas
Jul 22, 2003 07:53 AM
