Lifting a 2wd Dodge
Old Sep 18, 2008 | 10:33 PM
89f150's Avatar
Lifting a 2wd Dodge
Ok well this is that i did to the coils to make them fit a dodge. The coils are 88-98 Chevy truck coils. The ones i used are Fabtech coils.
Here are the pics of what i did to make them fit.
Looking at the coil.
Then i cut this much off.
Then on the other side.
And i cut this off.
Here is what the truck looked like before.
And after.
Thank
Jon
Old Sep 19, 2008 | 02:41 AM
PapeCAT's Avatar
are you sitting on the upper Control arm bump stops like that? I have the daystar spacers in mine and well lets just say that in bumpy situations and rollers the truck likes to spend most of it's time in the top 1/4 of the suspension travel, topping out regularly... How's the ride? did you have to do an alignment?
Old Sep 19, 2008 | 02:59 AM
Mattster's Avatar
Do you know if the springs are from a 2wd kit or a 4wd kit and 1500 or 2500?
Old Sep 19, 2008 | 06:02 AM
89f150's Avatar
havent driven it yet but it needed to be aligned already and i have to take that bump out. they are 1500 i believe 2wd
Old Sep 19, 2008 | 05:40 PM
I hope you put on some shoes before you broke out the cut-off wheel.
Nice write-up.
Before I got my '93, I had an '85 D250 gasser that had been lifted by using the diesel coils. Like Papecat's, mine was near the top of the uptravel and every time I went over a bump it felt like I was driving off a cliff. Let us know how it rides.
Old Sep 19, 2008 | 06:58 PM
89f150's Avatar
Haha this is like that all the way had to take the little bump off the upper. they seem softer so im put limit straps on it so i dont break balljoints
Old Sep 22, 2008 | 06:53 PM
89f150's Avatar
Here is a newer pic of the truck i have driven it a little, doesnt drive to bad
Old Apr 14, 2010 | 05:08 PM
whosdunit's Avatar
Ijust found this stiky !!! Wana what do i look for when you say up travle?, Maybe my trk.,is doing the same thing, i've cked., bottom bumpers not hitting they show very little ,lite marks on them. please tell me what to look for. Thanks.
Old Apr 14, 2010 | 05:12 PM
whosdunit's Avatar
89er., what length did you cut the springs over all length ? I like the lift look you got ,but sounds like you have a problem . let me know if you work it out. thanks
Old Apr 14, 2010 | 07:35 PM
There are bump stops under the upper control arms. My old D250 had about 1/2" before the stops hit, so the suspension was always running out of travel.
Old Apr 14, 2010 | 08:53 PM
huntinguy's Avatar
Looks like a 4x4 truck now.
Old Apr 25, 2019 | 11:27 PM
Hoover52's Avatar
What size tires are you running
Old Apr 26, 2019 | 06:41 AM
nonrev's Avatar
Super Moderator
10 Year Member
I don't think you will have much luck reviving a 9year old thread .... but in his sig he says he's running 285s so I think they are 285/75/16 same size I run
flathead
Sep 28, 2013 07:04 AM
wheatwhacker
Apr 17, 2008 03:47 PM
Dub-D250
Feb 13, 2008 08:41 PM
Grodyman
May 15, 2007 06:44 PM
rickd01
May 9, 2005 06:29 PM
