lifting 2wd front end
Old Feb 21, 2005 | 05:14 PM
flathead's Avatar
can anyone tell me if the front springs out of a 4wd would fit and lift the front of a 2wd?
Old Feb 21, 2005 | 06:54 PM
1ST GEN.'s Avatar
The springs on the 4x4 are bigger around, you could try spacers from daystar
Old Feb 22, 2005 | 07:00 AM
firestorm's Avatar
I added the 2.5" spacers from Daystar, and am happy with the way it sits.
Old Feb 22, 2005 | 10:11 AM
signature600's Avatar
Did you change anything else?
The 2.5" spacers I had moved EVERYTHING too far...the upper ball-joint nut was hitting the bump stop mount...everything was at the upper limit of it's travel, even with 4000lbs of weight on it.
I had to shave them down to ~1.75" to get it even close to being in spec so the alignment shop could work some magic on it...has been fine for 30K miles.
Old Feb 22, 2005 | 10:37 AM
firestorm's Avatar
I had to buy longer shocks, other than that,no. I still had about 3/4"-1" travel in the upper control arm adjustment, after the alignment was done.
Old Feb 22, 2005 | 10:57 AM
Dieselcamper's Avatar
I originally got the 2.5" spacers ,but after looking at them
I traded them in for the 1.5" spacers. Got them from
J.C. Whitney. There is still a slight 1/2" - 3/4" drop
in the front ,but with my trailer hooked up my truck sits
perfectly level.
Old Sep 26, 2013 | 10:39 PM
jbpena's Avatar
10 Year Member
ooold post but maybe u are still out there? Where did you get the longer shocks...how do you even figure that out?
Old Sep 27, 2013 | 07:07 AM
firestorm's Avatar
I disconnected the shock, and set the truck down on the ground. Measure the distance between the mounts, and use that as the center measurement of the new shock. Example: measurement is 15". Go to Napa, and find someone who is knowledgeable about shocks. Find one that measures 10" fully collapsed, and 20" fully extended. I may be wrong here, but I believe JC Whitney has custom shocks. Match the length, with the mount types, and get the heavy duty ones. It's been a few years, but I hope this helps.
Old Sep 28, 2013 | 07:04 AM
jbpena's Avatar
10 Year Member
Thanks man. I'll do that. And thanks for responding cause it sure has been quite a few years!
dodgebowhunter
14
Sep 10, 2008 10:01 PM
Dub-D250
Feb 13, 2008 08:41 PM
Grodyman
May 15, 2007 06:44 PM
EClancy
Dec 12, 2006 04:27 PM
rickd01
May 9, 2005 06:29 PM
