Lift pump blockoff plate
Old Jul 17, 2006 | 03:33 AM
bgilbert's Avatar
Seeing how Cummins thinks highly of their lift pump block-off plates, what gasser engine is it that has the same bolt pattern/spacer/block off plate? I know I've read it before. I see them in the gasser catalogs for cheap. I don't think it's a Chrysler 5.9, would be nice, I have one on the engine I pulled from the crew. Thanks.
Old Jul 17, 2006 | 06:03 AM
JD730's Avatar
Is it the same as a chevy? That seems to stick in my mind for some reason. I know I've read it before also.
Old Jul 17, 2006 | 07:37 AM
flashgordon's Avatar
I sec. it!
Old Jul 17, 2006 | 09:23 AM
Underpsi's Avatar
It is a chevy plate. you can just get one from napa
Old Jul 17, 2006 | 05:05 PM
ChrisLib's Avatar
I`ll third the chevy nod. It`s definitely NOT a small block Mopar,I just put a fuel pump on my 86 gasser before i sold it. I also happen to have my new piston pump sitting on my comp. desk and if memory serves me right it sure looks real close to a chevy .
Old Jul 18, 2006 | 02:52 AM
dodge250's Avatar
small block chevy's
Old Jul 18, 2006 | 03:51 AM
Begle1's Avatar
So, err, what's a "lift pump block-off plate"?
Old Jul 18, 2006 | 07:31 AM
Boatnik's Avatar
It is a plate that you put in place of the mechanical lift pump to keep the oil from leaking out of your engine where the old pump was mounted. It is used when you change to an electric or belt driven lift pump.
Old Jul 18, 2006 | 07:33 AM
JimmieD's Avatar
If you remove the mechanical lift pump and install an electric you need to block off the opening where the mechanical pump was....
Old Jul 31, 2006 | 01:45 PM
bgilbert's Avatar
Originally Posted by dodge250
small block chevy's
Is it a consensus that it's from a small block chevy? I checked jeg's and they show a 4 bolt cover for a sb chevy and 2 bolt cover for a bb chevy: http://www.jegs.com/webapp/wcs/store...chItemId=11907. Sure looks like it's gotta be the big block chevy cover ...
Old Jul 31, 2006 | 03:38 PM
apwatson50's Avatar
http://store.summitracing.com/partde...5&autoview=sku
Here you go, pretty expensive, lol.
Your local checker/autozone/advanced should have one also.
Old Jul 31, 2006 | 06:18 PM
I will 2nt gess with you and say yes to the big block........was hoping some one how had dun the block of already, would have chimed in by now
Old Jul 31, 2006 | 08:17 PM
Wolfeman's Avatar
I got one from Autozone and never could get to seal - it was warped.
Old Jul 31, 2006 | 10:56 PM
Jethrro's Avatar
Just did a piston lp swap got the old one in the garage to use for dimensions. Custom machine one for ya out of aluminum or mild steel if you need. Pm me if you need it. Jethrro
Old Aug 1, 2006 | 12:29 AM
bgilbert's Avatar
Thanks Jethrro, but I already ordered one from Jeg's earlier today. $5.99 a Mr. Gasket brand, comes with a gasket as well. Don't need any fancy billet aluminum etc, I'll be painting it Cummins beige after install to match my engine paint.
Edit: it definately is not the small block chevy or mopar. The correct block off plate is from a big block chevy.
Txwelder
Nov 26, 2025 01:53 AM
EverydayDiesel
Jun 14, 2010 10:35 PM
Redline Ram
Mar 16, 2007 12:39 PM
Txwelder
May 19, 2005 06:10 PM
mhuppertz
Nov 6, 2004 07:55 AM
