lift pump
Old Jan 19, 2007 | 07:26 AM
unclemarc's Avatar
lift pump
lift pump starting to leak more now,I've procrastinated long enough.Is there anything I need to be aware of while I change it out?{i.e. bleeding,etc.etc.}I'll be changing the fuel filter at the same time.Any and all your answers are greatly and much appreciated. marc
Old Jan 19, 2007 | 12:06 PM
Underpsi's Avatar
not really just a simple unbolt, and rebolting everything back up. The only thing you gotta watch for is not dsropping anything down in the hole and to scrap all the old gasket off
Old Jan 20, 2007 | 06:07 PM
unclemarc's Avatar
lift pump
Well I changed out the lift pump today,when comparing the old one to the new one with the manual prime lever I couldn't believe the difference in tension.Makes me wonder if I let it go long enough to put to much strain on the injection pump,I guess time will tell.It seems to idle a little smoother if that's possible or I'm just hearing things anyways thanks to all the reading I've done on this site it made the job easy for a first timer, thanks all. marc
Txwelder
Nov 26, 2025 01:53 AM
Txwelder
May 19, 2005 06:10 PM
Yukon Dodge
18
Jul 1, 2004 10:08 AM
Puke
May 22, 2003 12:18 AM
Haulin_in_Dixie
47
Nov 17, 2002 09:30 PM
