Let The Cold Air Blow
Due to two months of constant rain, and to having more pressing matters to attend to during the few less-rainy moments, I just this evening got around to "SUMMERIZING" our trucks.
I removed the winter-time fan-clutches and installed the summertime "pinned" direct-drive clutches.
I love to hear the fans over the roar of the engine, sounding like a turbo-jet winding up; it sure is reassuring to know that the fan is doing it's optimum-best, with no wimpy clutch to slow it down.
I also remembered to close the ball-valve in the heater-hose of my truck, thus stopping the flow of HOT coolant into the IN-CAB air system.
The wife's truck has some kind of vacuum-operated gizmo that is supposed to stop the flow of coolant into the heater-core.
My understanding is that, when A/C is selected, a vacuum signal tells this valve to close.
How do I know if this vacuum valve is functioning ??
Can I see it operate, while someone in the cab operates the switch ??
Thanks.
Thanks.
This is on my Ford/Cummins; and, due to differences in engine-bay design, I didn't utilize the steel coolant tubes; but instead, in the upper hose position, I installed a pipe nipple in that port, then an elbow, then another nipple, then ball-valve, then 5/8-barb into the hose.
The valve is immediately behind and above the alternator.
On the wife's ALL DODGE/Cummins truck, I am going to take one of the steel tubes that I didn't use on my truck, cut it in two, splice in a ball-valve, paint it nice and pretty, then replace the tube on her truck with the valved tube.
That silly vacuum-gate may or may not work; I KNOW whether or not the ball-valve is working.
On all of our trucks, I can feel no loss of power and no noticable change in mileage whatsoever.
If the engine can muscle sixteen big Charolais cows up Russell Creek Hill and not take a short breath, it isn't gonna notice a silly little old fan.
YES SIR, I did.
The first clutch I ever pinned was on an old gas-burner Bronco.
At that time, I did not know there was such a thing as an un-permanently-connected fan.
The fan quit turning and the engine started heating up; a replacement fan-clutch cost more than I paid for the Bronco, so I thought my way through the dilemna, drilled entirely through the clutch-housing, installed a Grade-8 bolt/nut, and it was still running like that ten years later when I finally let someone else have it.
When the shop that completely rebuilt the entire A/C system on the wife's truck installed the fourth NAPA fan-clutch in two days time, I told them to dig the old one out of the dumpster, I took it home, drilled/tapped four holes through the face, loc-tited and safety-wired Grade-8 bolts that pressed the internals firmly together, stuck it on the engine, and problem solved for good.
The guys at the A/C shop were amazed.
Red3quarter
Dec 12, 2009 11:12 PM
Drivvven
Apr 20, 2006 06:24 AM
