LED turn and tail lights.
Old Mar 26, 2009 | 10:52 AM
  #31
Fruitman's Avatar
Has anybody else had the fog light bulb on the drivers side go out more than once yet? Maybe I have a short. Is it easy to determine if you have a short somewhere? Before I replace this bulb again I'd like to check the three locations that I've had to replace bulbs at, multiple times (pass brake 2, drive fog 3, drive running 1).
Rob
Old Nov 27, 2009 | 11:43 AM
  #32
Twitchy's Avatar
Question
The light house no longer carries Heavy-Duty Lighting products.
Any one know where else they can be purchased online?
Jim,
Do you have any special kind of flasher installed and/or resistors between the LEDs?
Old Nov 27, 2009 | 02:47 PM
  #33
www.vleds.com
and www.superbrightleds.com have a huge selection.
i like vleds products better
Old Apr 25, 2010 | 10:05 AM
  #34
RuralCruiser007's Avatar
With the increase of use of LED's Grote has developed several different flashers for different flashers applications. They make one that replaces our flasher, part number 44891. http://grote.com/product.php?product_number=44891
I have used these flashers for different applications to fix unbelievably fast flash rates.
Glenn
Old May 1, 2010 | 06:22 PM
  #35
james1's Avatar
Question LED 1157A's in the front blinkers
You can get LED 1157A's to go in there.
I just put two LED 1157A's in the front of my truck. With only a blinker on (or the emergency flashers) everything works just fine. But when I'm running the parking lights, the blinkers refuse to work at all. I already upgraded to the electronic flasher unit. Any ideas?
TIA
Old May 2, 2010 | 04:10 PM
  #36
Yeah, the front signals ground through the side markers.
There are a couple of ways to deal with it. You can run a separate ground for the turn signal/parking light bulb, and then run the side marker as just a marker.
Or you can get an LED lamp assembly that does marker and signal duty and custom fit it to the fender, then wire that up in parallel with the turn signal/parking light with new grounds for each.
Old May 3, 2010 | 01:37 PM
  #37
james1's Avatar
Question
Are blinking side marker lights required by law for vehicles made after a certain year model?
That's more trouble than I'm willing to go to just to have LED bulbs.
The OEM front signal bulbs are 2057A's (incandescent). Is it possible that someone may eventually manufacture the 2057 in LED, or does this grounding issue mean an LED bulb will never function properly in our front signals?
TIA
Old May 3, 2010 | 04:21 PM
  #38
unixcowboy's Avatar
TIA
Yes
It's not so much a grounding issue as it is an LED issue.
The side markers try to ground thru the park/turn lamp. When the parks are on the side markers supply +12 to the - normal - ground. The LED becomes reverse biased and shuts down.
When the LED shuts down there's no ground - hence no blinky
Old May 4, 2010 | 08:45 AM
  #39
deking1970's Avatar
I am running the 1157A bulbs and the same side marker that Jim Lane is running. Can I do this?
Or you can get an LED lamp assembly that does marker and signal duty and custom fit it to the fender, then wire that up in parallel with the turn signal/parking light with new grounds for each.[/QUOTE]
Diesel Junkie
Dec 23, 2014 03:01 PM
PCM
Nov 11, 2008 08:25 PM
Patriot2500
Jun 25, 2008 08:47 PM
CHarlan
Aug 6, 2003 08:40 PM
diesel dave c
Dec 16, 2002 12:00 AM
