Leaking WIF Sensor
Old Feb 21, 2009 | 08:48 PM
cedardiesel's Avatar
Leaking WIF Sensor
I got a problem with my Water In Fuel sensor leaking and I have replaced the sensor itself because the original one was leaking also. I have been running the solid bottom filters for some time and didn't have a problem but would like to have the sensor operable just for the peace of mind that if I happen to get a bad batch of fuel. Any help or advice is greatly appreciated.
Old Feb 21, 2009 | 09:24 PM
93John's Avatar
Make sure to change the oring every time you change the filter. Don't over tighten it, the sensor is only plastic. It could have cracked.
Old Feb 21, 2009 | 09:42 PM
You can get a new WIF sensor from Cummins directly or from Geno's.
Old Feb 21, 2009 | 10:07 PM
Already Replaced O-rings and already replaced the complete sensor.
Old Feb 22, 2009 | 05:46 AM
gcliburn's Avatar
Check the o-ring above the fuel heater. Mine did the same as yours finally figured out it was that top; ring.
Old Feb 22, 2009 | 11:06 AM
Yea I believe that is my problem. You wouldn't happen to know the part number for that o-ring?
Old Feb 22, 2009 | 12:28 PM
Ramrod90's Avatar
Or mabey a part # for that fuel heater delete pluggy thingy.
Old Feb 22, 2009 | 12:42 PM
sdstriper's Avatar
(I'll correct myself and confirm this number... From Cummins Quickserve), Rectangular ring seal p/n 3913695, you better confirm this one, it was greased up and smudged...
Fuel heater delete adapter p/n 3925954
Last edited by sdstriper; Feb 22, 2009 at 12:57 PM. Reason: Correction and p/n confirmed
Old Feb 22, 2009 | 12:59 PM
sdstriper's Avatar
I confirmed the p/n and corrected the part description
Old Feb 22, 2009 | 08:37 PM
Do I really need the Fuel Heater cause I live here in Lebanon,Tn and it doesn't really get below 20 degrees all that often cause if I don't need it I will definately get that adapter.
JBOND
Feb 18, 2008 08:36 PM
withalligators
Dec 21, 2007 07:48 PM
Crimedog
Oct 23, 2007 08:37 PM
spunbearing
Apr 18, 2004 06:00 PM
FUNX4ME
May 7, 2003 08:32 PM
