WIF Sensor
Old Apr 30, 2003 | 02:22 PM
FUNX4ME's Avatar
WIF Sensor
Anybody ever have a problem with their WIF sensor leaking?Yesterday my truck didn't want to start,after about the third try it started and ran rough for a while.I smelled diesel so i looked under the truck and had a steady driping of fuel.It seemed to be coming from the WIF sensor.Just wondering if anyone else has had that problem.I've got a replacement coming from Geno's.Thanks
Old Apr 30, 2003 | 03:03 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Re:WIF Sensor
I had a problem with it leaking when I tried to use a purolater fuel filter. It would not seal properly, and after getting a Wix filter to replace it with, it was obvious that the filter was substandard and would not allow the o-ring to seal.<br><br> Last time I ever considered a cheap filter of any-kind on my truck.
Old Apr 30, 2003 | 10:26 PM
Ray,IN's Avatar
Re:WIF Sensor
LEAK!!!!! I had the water sensor drain valve come out and disappear once. I was towing at about 65mph and noticed the engine running rough. Stopped at an exit and discovered a 1/8&quot; stream of fuel running under the truck. That resulted in a tow bill and finding a new valve at 10pm. The valve was the original installed in a Fleetgard fuel filter. I now carry a spare sensor/valve in toolbox. P.S. A 7/16&quot; bolt will plug the opening in this emergency situation, I discovered later.
Old Apr 30, 2003 | 10:51 PM
SjLingenfelter's Avatar
Re:WIF Sensor
When I first saw it said WIF sensor I thought &quot;Wife Is Frustrated&quot; sensor. lol sorry I had to put it.<br>SD03
Old May 7, 2003 | 08:32 PM
FUNX4ME's Avatar
Re:WIF Sensor
It turned out to be a cracked fuel line.The rubber fuel line that runs right along side the block was rotted with many cracks in it.The truck is a 95 and just turned 150,000 miles.Just something to think about if you have one with that many miles
cedardiesel
Feb 22, 2009 08:37 PM
JBOND
Feb 18, 2008 08:36 PM
withalligators
Dec 21, 2007 07:48 PM
Crimedog
Oct 23, 2007 08:37 PM
spunbearing
Apr 18, 2004 06:00 PM
