leaking fuel line nut
Old Aug 15, 2009 | 06:23 AM
minipete's Avatar
hello guyz, today i noticed when i had my hood opened up that i have two fuel lines leaks coming from the nut that connects to the injectors and the fuel lines. i tired snugging em up but they seem pretty snug already and still leaking. what can i do to get em to stop leaking? is there a o ring or something that could of gave way? thanxz in advance Dan
Old Aug 15, 2009 | 08:42 AM
John Faughn's Avatar
High pressure leaks can eat a grove into sealing surfaces , so you would need to lift nut & line , use a magnifying lens to see if the sealing surfaces are OK .
Do not undo just one end , you want to lift the line without bending , by loosening both ends & clamps .
The use a torque wrench to tighten , I do not have the spec. for that handy .
Old Aug 15, 2009 | 07:52 PM
Often you can get them to reseal by cracking them loose while the truck is running, letting them squirt a little bit to clear out anything that might be keeping the flanges apart, then retightening.
wisconative
May 13, 2013 07:20 AM
Clane
Jun 2, 2012 03:31 PM
quick1300r
Sep 29, 2011 11:09 AM
txasylum
Mar 22, 2008 02:47 PM
bwat4
Feb 6, 2004 09:32 AM
