1st Gen. Ram - All TopicsDiscussion for all Dodge Rams prior to 1994. This includes engine, drivetrain and non-drivetrain discussions. Anything prior to 1994 should go in here.
The ksb is leaking from the screw in plug on the front of it closest to the timing case. It's dripping steady when the truck is running. Seems to have started after I installed the new lift pump. I have not had a chance to check fuel pressure. Would this even cause this to leak?
The truck runs well just leaking a bit. I tightened the plug and it did not help. Can this be fixed on the truck? What do I need to fix it? Thanks
I hope you didn't get one of those cheap piston pumps that put out 40+psi. It will push the front seal out of the VE and fill the crankcase with fuel. If you have a piston pump you definitely need to check the pressure.
No I got one from dieseltuff that he setup for the ve. I did check the oil and the level has not gone up. I have about 50 miles on the new lift pump.
OK. Then you got the same one I got. I checked my pressure and it's 15 psi at idle. Good job.
You can get the genuine Bosch seal kit DGK-121 off ebay for around $20. Sometimes Amazon has them for cheap. I think you can remove the KSB from the pump without pulling the pump.
