King pin bushings
King pin bushings
I just ordered bushings, springs, spring retainers, grease seals, and gaskets for my upper king pins. They should be here before this weekend.
It really needs a complete upper and lower rebuild/replace but I won't have the shop space to do it until this summer. I want to see if just installing new bushings and springs will get me by until then (I'm all over the road and chewing up tires something bad).
I read the sticky and the FSM but haven't found any instructions on just doing the bushings. Is it as simple and straightforward as it looks?
Am I missing any parts for this job?
Any odd or special tools to make it easy?
Thanks guys.
-Niemand
Thanks guys.
-Niemand
Thanks guys.
-Niemand
Thanks guys.
-Niemand
N. Besonderes (02-21-2018)
Received 1,637 Likes
Do the passenger side first. Its much easier with no Drag steering arm to contend with.
Sometimes putting it all back together with the steering arm still attached to the drag link is a pita.
You don't always have to change out the upper king pin cone if it doesn't appear to be severely worn or scored by broken parts or sand infiltration. It usually can wait till a full rebuild is in order
Relatively fast job otherwise
I will be doing mine soon. This maybe be helpful
Pirate4x4.Com - Extreme Four Wheel Drive
That's the kind of brain droppings I'm looking for. Thanks Tman!
It made a noticeable improvement. I still have unevenly worn tires and need to do the full King Pin job, but I can live with this for now.
Thanks fellers.
-Niemand
Thanks fellers.
-Niemand
oliver foster (02-28-2018)
Great
Rotate your tires, and fuggetaboutit
Fuggetaboutit!
Tommy93w350
09-30-2004 02:36 PM
