keep blowing fuse
Old Feb 25, 2011 | 03:11 PM
12valvewagon91's Avatar
keep blowing fuse
91.5 D250,
keep blowing the blower fan, window motor, fuse, new blower fan motor already on it with new connectors, all the fusable links are eliminated with new style fuses. Could it be my fan speed switch, or could my ac compressor have an issue. It only does it when the truck is on defrost, and high speed, but its intermittent as hell.
Kasey
Old Feb 25, 2011 | 04:15 PM
GIT-R-DONE's Avatar
I would check the switch wiring or the switch itself
Old Feb 25, 2011 | 06:14 PM
SORTIE's Avatar
the wiring in these trucks is ca-ca. only the paint jobs was of lower quality. shame on Chrysler engineers for thinking that their design would be reliable
at some point the whole mess needs to be rationalized (i.e. REPLACED)
(don't ask me how I know )
Old Feb 25, 2011 | 06:36 PM
I know in my old 78 the heater wireing sucked and my fuse block was a melted blob of gooo. I had to wire in individual fuses into the block.
Kasey
Old Feb 25, 2011 | 08:54 PM
307Kenworth's Avatar
My long term goal on my 91 is to re-wire the whole rig, and do a custom dash with probably Isspro gauges and a spot for a bunch ( I mean a BUNCH) of toggle switches to run everything, and building a flat shelf on the drivers side inner-fender to hold all the fuse boxes and relays that I can dream up for electrical stuff!
As for the problem at hand, I'd check the switch unit and the pigtail harness right on the HVAC control unit.
Old Feb 26, 2011 | 06:47 AM
Trebor's Avatar
Did you check for any trash blocking the air flow in the heater box? Trash getting stuck in there is a common problem which could make the blower act more like a compressor.
Old Feb 26, 2011 | 07:42 AM
Dick Rector's Avatar
i kept blowing my window motor fuse when the motor was starting to go i replaced the motors and the regulators ($120) at the local oreilly and that took care of my problem
Old Feb 26, 2011 | 07:53 AM
the fuse in the fuse boxes dont blow, its the 50amp fuse I wired in at the engine bay in place of the fusable link, how heavy amp wise are the fuseable links suposed to be? I have a new fan motor, new window motor, and the wireing looks fine nothing melted. The book shows 20 guage fusable link.
Kasey
Old Feb 26, 2011 | 08:45 AM
I just replaced the fan switch, so well see. Im also thinkin the heater control could be it it feels a little funny, really loose.
Kasey
Old Feb 26, 2011 | 09:16 AM
sooty's Avatar
check the sticky for a wiring upgrade for the fan high speed, youll get 2-3 times the cfm, with larger wire through a relay, at the same time reducing load on the original wiring, which is too small of gauge, too much loss of voltage, its a very worthy job when done.
Old Feb 26, 2011 | 09:31 AM
What is the "sticky" and does someone have a link to this for me?
Kasey
Old Feb 26, 2011 | 10:01 AM
921stgen's Avatar
Its at the top of the 1stgen page. https://www.dieseltruckresource.com/...t-t102027.html
Old Feb 26, 2011 | 10:15 AM
I found it, thanks guys. Ill be doing this here shortly.
Kasey
dieselfreak21
Aug 31, 2009 02:49 PM
Grim Reaper
Feb 19, 2009 11:25 AM
89dieselkong
May 6, 2007 07:57 PM
mr T
Sep 15, 2006 09:36 PM
roberts11260
Jun 27, 2006 07:43 PM
