Intercooler boot blew
Old Oct 24, 2005 | 05:00 PM
sammy340's Avatar
On my way home today i was hitting about 35 PSI of boost when i heard a loud noise come from under my hood, and i instantly lost power. I was about 10 km from home so i just limped it there. When i got home i popped the hood to find one of my IC boot exploded. There was a little bit of oil in it as well.
Once i saw the oil i got scared and thought turbo bearing, but i cleaned everything up and fired the truck up with the IC boot off and there seems to be no oil blowing out the compressor discharge.
Now, why was there a little bit of oil in there? There is none at all downstream from the first boot..........Was it from running the truck without a boot for awhile? Or was it just from a instant 35 PSI to zero boost condition creating a little bit of oil to blowby? Or is the turbo bearing screwed?
Myabe i should just put on the new boot and test it for a few days.... then look for any oil in the discharge piping?
Thanks for help
Jeff
Old Oct 24, 2005 | 07:13 PM
SmokinFive9 4x4's Avatar
Be ready to yank that tube off if she starts runnin away!
Turbo doesn't seem loose? There's no oil in the compressor outlet?
Old Oct 24, 2005 | 07:26 PM
sammy340's Avatar
wannadiesel
Turbo doesn't seem overly loose. There was oil in the compressor outlet, but i wiped it away and it don't blow oil anymore. I think it was just maybe leaked a bit when it blew due to sudden pressure differential?
I tested it at idle with no load on the turbo, and it didn't leak. Do turbo's only leak oil under load if the bearing is shot?
Old Oct 24, 2005 | 07:30 PM
I dunno. I think your theory makes sense. It's not puking oil out at idle, so I think you ought to put it back together and drive it for a week or so, then pop the boot off and take a look. If it's oily again you'll need a rebuild.
95black2615
Oct 8, 2008 03:34 PM
gunracer1
Jan 20, 2007 02:23 AM
DuallyMan
Sep 4, 2006 11:40 PM
goodtyms
Jun 2, 2006 10:50 PM
csaverline
Oct 23, 2002 04:55 PM
