Installed a BHAF today
Old Oct 13, 2012 | 06:39 PM
Jaybird1962's Avatar
Been going to do this for awhile. Order all the parts last week. Was nice out so Installed a BHAF today.
Old Oct 13, 2012 | 07:44 PM
TJE's Avatar
TJE
Looks good! Give some detail on how you made that thing!!
Old Oct 13, 2012 | 09:19 PM
Diesel Dave2's Avatar
Pickin on the wrong admin...
Wow...Nice... on the fab work on the BHAF housing...
Old Oct 13, 2012 | 09:38 PM
What the heck is that...A big honking soup pot!!! Looks great!!
Old Oct 13, 2012 | 09:44 PM
.....I looked at it again...You right....I think I got the same pot in my kitchen...I would never have thought about using it as a housing...
Old Oct 13, 2012 | 09:59 PM
Well close. It's a strainer from a outdoor turkey fryer that I won like 12 years ago. Never used the strainer and measured it and wow worked out. Had to cut 5 inch hole in the end and shorten the pot 2 inches. On the edges that i cut went to part store and bought the chrome door edge trim $2.99 to cover the hole and the end that I cut. Did not have enough left over to cover the slot I cut out where the cold air vent from the factory air filter hits it so I used tape on that edge but no one see it .On the back end its open but sits against the fender. I took a 1 inch metal strap and screwed it across the back to keep the filter in place. You can see 1 of the screws for that on the back edge of the pot above the slot I cut out. Took 2 screws and on the fender lip attached the pot so it would not move. To change filter have to take off tube running to turbo and the 2 screws on the fender lip. Then the 2 screws that goes across the back. Not a lot of work to change. But will not have to do that very often .
Old Oct 14, 2012 | 07:12 AM
longshotranch's Avatar
Now all the hot air from the engine can get in through all those holes.
Old Oct 14, 2012 | 07:58 AM
[QUOTE=longshotranch;3138776]Now all the hot air from the engine can get in through all those holes.[/
Only like 6inches of the filter sits out in the engine bay. Most of the filter sits back in the fender. The back of the filter sits against the fender. I cut a slot in the air housing where the out side air vent from the factory air box hits. Hoping to get some outside air to the filter.Well I will see how it works if seems not better will put the old back in.
Old Oct 14, 2012 | 01:28 PM
Bill Tomlinson's Avatar
I cut holes in my stock air box. When it is hot out AND I am pulling hard, I duct tape them. Up here in the north, I just wish I had to keep the tape on more often. Just picked up a mig and am going to do something better for a bhaf. It won't be pretty but it should work!
Rickcher
Sep 2, 2009 05:08 PM
Ace
Oct 31, 2007 06:46 PM
CumminsRedneck
Oct 15, 2006 11:08 AM
