Inlet thread to the almighty VE
Old Jul 4, 2006 | 01:43 AM
bgilbert's Avatar
Anyone tell me what size the inlet thread to the almighty VE is? This way maybe I'll stop hounding KTA with questions.
Old Jul 4, 2006 | 06:56 AM
JD730's Avatar
Which one Bill? The one right in the case or the one in the adaptor that is there.
Old Jul 4, 2006 | 12:38 PM
Underpsi's Avatar
I think I used a 3/8 to 1/2 reduce NPT not sure if it is the correct thread or not but I was able to use it without messing the threads up in the pump and it still steals perfectly fine
Old Jul 4, 2006 | 02:02 PM
JD730's Avatar
I just got done checking on my parts pump. The inlet in the pump body is metric, big surprise there, 12mm x 1.5 this is also the same thread that the banjo fitting on my 2000 had before I replaced them with a big line kit. The adaptor that is normally there is what I think is 1/4 straight pipe thread. 18 threads per inch. My 1/4" NPT taps fit perfectly only they are tapered.
Old Jul 4, 2006 | 02:15 PM
bgilbert's Avatar
Thanks guys. I gotta start buying more parts now.
Old Jul 4, 2006 | 02:23 PM
Underpsi's Avatar
I guess it was a 1/4 to 1/2 adapter then I couldn't remeber what size exactly but I knew it was NPT
Old Jul 4, 2006 | 02:40 PM
bgilbert's Avatar
Hey is JIC the same as AN fittings?
Old Jul 4, 2006 | 03:07 PM
JD730's Avatar
IIRC AN fittings are the same as JIC, They both have a 37* angle on the sealing surface.
JWood
Jan 19, 2009 07:18 PM
bcool
Aug 2, 2008 01:39 PM
mysterync
61
Nov 18, 2005 12:07 PM
signature600
Mar 26, 2004 02:33 PM
