Need help want to get some add ons
i got 3/4 92 dodge 3in straight pipe got the stuff to put on 5in stacks stock pump tweaked almost all the way just need to find right dye to get the weld of the one screw got a shift kit got k&n filter wondering about some small add ons such as some bigger injectors maybe diff turbo and govenor spring 3200
i want to pull at only three local fairs and still have desent truck to pull trailer some of the time
were i could get these things and what u guys think would be best things to buy and how big of injectors would u go with what i got thanks
If you want a cheap and dirty 300 HP, get POD's (off Ebay), a 16 cm turbine housing, and an HTT Stage III compressor upgrade from HTT. Get the 3200 RPM spring from an injection pump shop. With a few pump tweaks those parts will get you about 300 HP at the back tires for under $1000. I will get hot towing, though. If you tow a lot, spend a little extra money and get the Bosch 190 injectors from PDR. They won't make quite as much power, but the EGT's will stay a lot lower towing.
What Dave said. You're asking for the two extremes of performance when asking to tow (a trailer) and pull (a sled). You'll have to make a compromise somewhere, and depending on budget, injectors will probably be it.
If you wanted to expand you budget a bit you could get all what Dave said with the PODs and a H20/Meth injection kit and you will get more power and may be able to keep it cool enough to tow. Not sure though someone else will have to chime in. The downside is if you buy a name brand kit (which are nice kits) it will be roughly $500
I totally agree with what has been said before. Just add a 4inch DP to that list, I am kind of after much the same as you. I need my towing capabilities, but come on its a cummins, u better believe i'll be "playing" with er!
Where in NY are you loacted? me and Greg (G1625S) are just outside of Binghamton, greg helped me out lots, awesome guy! either of us would be glad to help ya out. Im not home much though I drive OTR.
the pods what am i looking for im new so need little more assistance as far as all the parts it would be so much help to get me in the right direction cause it seem every time i go to look for the things u guys tell me i come up with whole lot of nothing
ocsurf16
Jan 10, 2006 07:31 PM
shortfieldbreak
Feb 25, 2003 08:15 PM
