injector pump removal
my injector pump is almost out.
I have all the lines and bolts out, but it is hanging up on the gear inside the gear housing.
I did remove the bolt from the from of the housing.
Is there anything else that holds the shaft in, or do i need to apply more force?
You need to use a gear puller to pop the gear off the shaft. Make sure you don't drop the key.
HUNTINNUT
07-27-2013 11:40 AM
trik396
06-01-2008 07:04 PM
TJ0993
11-08-2007 10:27 AM
kawi600
01-26-2006 10:19 AM
