injector pump removal
my injector pump is almost out.
I have all the lines and bolts out, but it is hanging up on the gear inside the gear housing. I did remove the bolt from the from of the housing. Is there anything else that holds the shaft in, or do i need to apply more force? |
You need to use a gear puller to pop the gear off the shaft. Make sure you don't drop the key.
Well, then we could hand them their "Stupid" sign. ;)
