Injector lines?
Old Jun 18, 2008 | 03:40 PM
Montana2x2's Avatar
Injector lines?
The last time I changed injectors was while replacing the head so the lines were off. Is it possible to replace injectors with out removing or loosening the lines at the IP? Thanks.
Old Jun 18, 2008 | 04:06 PM
C/PRD/'s Avatar
I change them without removing the line completly. I do break them loose and remove the line supports though.
Old Jun 18, 2008 | 04:09 PM
bgilbert's Avatar
I never touch the lines at the IP. Simply remove the valve covers on both sides of the injection lines, example 1 and 2 and maybe 4 and 5. Whichever ones each set of lines pass by. Then remove the 10mm bolts that secure the injection lines to the intake cover plate. This will allow a range of movement of the lines to R&R injectors.
Old Jun 20, 2008 | 11:05 AM
Montana2x2's Avatar
Thanks guys, I'm due for a valve adjustment too so I'll do it all at once.
4doogie
Mar 10, 2006 01:46 PM
Gene007
Feb 27, 2006 09:34 PM
rockjeep73
Feb 1, 2006 10:34 AM
MrKen
Feb 25, 2005 04:22 AM
hellotbone
Sep 1, 2003 08:46 PM
