Injector Leak
Injector Leak
Tonight i was driving and noticed the smell of diesel, and when i parked, I saw fuel running down the block and dripping on the ground.
turns out, when the trucks idling i have a fuel leak with little bubbles coming out right where the injector body goes into that big nut thats in the head on cylinder #6 , at first i thought it was the return line copper washer leaking but i tightened it up and tightened up the main line on top and still leaking.
and it leaks when i shut it off too, which makes me think it's something to do with the return
5 days ago i replaced the fuel filter and filled it with Diesel Kleen like i always do.......
2 days ago I removed the injection lines off the injectors to move them out of the way so i could retorque the head, Also removed the valve covers and re-used those gaskets since they weren't leaking before, i left the gaskets on the head and just took the covers off.
Now i get it back together and i got this leak, #6 valve cover is also leaking oil
which is mixing with the fuel that #6 injector is leaking and it's making a nasty oily/diesel mixture that's running down my bellhousing/block
I guess tomorrow I'm gonna pull that injector with my puller, and see if i can clean it up and figure out why it's leaking. I hope the injector body is not leaking.
I've heard of the injector bodies loosening up a little sometimes. You could put a wrench on the injector body and see if you can snug it up a bit more. If that's not it, it could just be the copper seal in the head? Clean up the sealing surface inside the head before re-installing it.
Everything I've searched and read says to try tightening the locknut with a deep socket after i taket he lines off? I'll try that when i get home
I just fired it up cold an hour ago and it ran like absolute crap until i brought the RPM's up and it cleared out.
Hahah wow it was the nut that goes into the head. It was real loose, I used like a 21mm deep socket and it sealed the leak right up.
Crazy how it just started leaking all of a sudden.
george7941
Nov 28, 2009 09:28 PM
superdiesel9
Oct 25, 2009 07:56 PM
donhov
26
Jan 6, 2006 07:29 PM
Lightman
16
Jan 21, 2004 10:46 PM
