injector ?
How much fuel can be pushed through small stock i/c injectors. I've heard if you turn the pump up to far to make power. It can't push the fuel through the small injectors, and the pump's life will be shortened. Can you make 350hp with them?
I bet you could get 300hp or more out of stock i/c injectors. I made 307hp with my HE351 and PODs. But I think If i had the turbo i have now and had a better fuel supply and got my power to the ground then i bet I coulda broke 300hp with my stock injectors. I could hit 40 lbs of boost with my stock injectors with my HE351. They will probably keep poppin shut off solenoids though since they don't flow as much and it may shorten your pump life span. Non i/c injectors do flow more.
TJ0993
Nov 8, 2007 10:27 AM
gablekevin
Sep 19, 2006 12:12 AM
kawi600
Jan 26, 2006 10:19 AM
oscaroc
Apr 2, 2005 12:14 PM
