Injection pump leak
Injection pump leak
91 non-intercooled, noticed diesel smell today, injector pump seems to be seeping around throttle shaft or control valve. Truck still running and starting fine. Wondering if this needs to be addressed quickly or when I have time? Pump has always been dry, truck has about 160,000 on it. Thanks
It might seep for a while or it might just start pouring fuel out right away. Best just to fix it, there's re-seal kits on ebay
Hadn't run any additives. Thought about it but hadn't decided what to run. Looked today and it is throttle shaft seeping. Any one know how hard or easy a fix that is? Thanks
look in the stickie, same job to seal fuel pin oring, gov spring will be right there, removing the cover, take time to understand the simple job it is, youll do fine.
tommurray
02-23-2014 10:38 AM
