Idle 450 rpm
Old Apr 26, 2006 | 07:38 AM
ruquik's Avatar
Idle 450 rpm
I was at about 600 untill i installed the POD's and then it dropped down to 450. Now i can hear a small "squeal" (similar to a worn out tension), but as soon as I bring the idle back up to 550-600 it goes away, I just replaced the idler so i know its not it.
Old Apr 26, 2006 | 07:40 AM
Micaiahfied's Avatar
is there a reason you a running idle so low? or are you having trouble raising it?
Old Apr 26, 2006 | 10:48 AM
Tuckerdee's Avatar
Idle should be 750-800 in D with the A/C running. The squeel I think is your belt slipping because your engine is basically speeding up and slowing down really quickly about 450 times per minute since your idle is so low.
Old Apr 26, 2006 | 01:17 PM
bgilbert's Avatar
Your tach probly isn't calibrated correctly. It shouldn't run at 450rpm. It's probly at 600 NOW, which is very slow and the engine sounds like you describe. Anything less and it will die. More fuel or low idle screw will bring up your idle.
Old Apr 26, 2006 | 06:09 PM
Turn up the main fuel screw.
ClayBob
Aug 7, 2009 09:41 AM
jmccart
Jun 12, 2007 02:12 PM
fishin fever
Feb 22, 2004 08:32 PM
StakeMan
28
Jul 16, 2003 12:15 AM
jlells01
Feb 12, 2003 01:11 AM
