Identifying a turbo?
If i was looking at a turbo how do i know how big the turbine wheel is? What could i use to measure it? Does anyone know the serial numbers to look for? The one im looking for is a hx50 but my cousin said he has some htb3? i think that is it what are the specs on those thanks jon
I also have this question.
I bought my truck already modded and have been able to ID most everything the guy did to it except the turbo. I know it helps the pros on this sight to know what we have when we have questions and Id like to add it to my profile.
how do I identify what turbo I have?
well i called cummins and this is what they told me
ht3b ranges from 108-13? comp wheel and 22-36 exh. housing
hx50 92-98 comp wheel and 22-32 exh. housing
i mentioned running a hx50 and he laughed he said hx40 would be plenty
You're not gonna want a stock hx50 from the junkyard or ebay. Won't bolt up, won't spool up (very good), won't make any HP in the rpm limited VE pump etc etc. The only one you would remotely be interested in is one of the Holset performance HX50's, known as the Pro52. You won't find it on anything in the junkyard. It's a performance charger designed to be used with the 5.9 Cummins. Available only from a Holset dealer/distributor or diesel site classifieds. Even then its iffy on making VE power.
The ONLY chargers you should be looking for from the junkyard is the hx40 with a 16cm wastegated housing or a s300 with a T3 bolt up turbine housing. Both are rare and hard to find in a junkyard because they are only used on newer models. The hx40-16 being found on the 8.3L C-series 24 valve Cummins. Most C-series you'll come across will be 12 valves with much less desireable T4 non-bolt up massive turbine housings. 18, 19, 21cm wastegated and non. Don't waste your time or money on these. The s300 will be on a 3126 Cat. Most of the ones I've come across have the T4 turbine housing and slip boot compressor housings though. Like I said, it's hard to find a good bolt on charger that will work well with a VE motor in the junkyard.
To answer your question on how to measure compressor and turbine wheels. You'll need a dial caliper. The smallest measurement on each wheel is the number you want.
yeah my compressor is upgraded for sure, I have a box of all the old parts and havent had time to really look them up.
I know its a holset and I think he said its a HTT stage 2 upgrade (does that sound right?)
It wales out close to 40psi if I let it... has a BHAF too and 4" all the way out.
thanks again.
thanks again.
raffshore
12-21-2009 10:52 PM
Gilberts2500Ram
12-04-2005 10:09 PM
Turbo Deeezle
12-02-2004 09:01 PM
