"it iddles to low"
Old Sep 28, 2010 | 04:41 PM
whosdunit's Avatar
"it iddles to low"
I bumped my time up 1/8, turned power screw up 1/4 turn( that's all it would go ---has coller stp.) It runs loads better.THANKS FOR STICKY'S. It idles fine but,,, some times when i stop it pulls down to low, it seems the darder i push on brk., peddle it pulls even lower,,any gusses???
Old Sep 28, 2010 | 06:26 PM
Sounds like a vacuum pump issue? Perhaps the pump is working too hard to keep the vacuum up and is drawing a bigger load on the motor.
So could be your vacuum pump or you brake booster? Check to see how much vacuum you have.
Old Sep 28, 2010 | 10:12 PM
Bencie's Avatar
If it has an auto trans maybe the torque converter isn't stalling right? Just a thought.
Old Sep 29, 2010 | 10:52 AM
whosdunit's Avatar
Hey thrash; I thought ,vac., or my power steering pump, even though the pump don't make any noise. The vac. pump is re buildable i think. It hss been getting steadly worse. THANKS .
Old Sep 29, 2010 | 08:17 PM
#2isgreen's Avatar
Unless it's untaxed, then it's red.
do you have a tach? what happens if you drop it in neutral while its pulling down the rpms?
also if its a low vac issue the parking brake and ABS lights should light up when the vac drops too low.
Old Sep 29, 2010 | 08:46 PM
whosdunit's Avatar
#2 no tach.(i'mlooking) sometimes it pulls down in net., but not every time ,the abs -park lite were born "ON" in some of these old-er modles(ha), i'm working on that too.
Old Sep 29, 2010 | 09:05 PM
#2isgreen's Avatar
the vac pump is mechanically driven so if your idle is too low it might not generate enough vac. i have my idle set just high enough to keep the abs/parking light off while i'm in gear at a red light. if it does come on i shift to neutral the engine speeds up enough to get the vac running hard enough to turn the lights off. when you played with your power screw timing you may need another hundred or two rpms ( if you had to turn down the rpms like most pumps need after those adjustments). super easy to do that once you've taken the low idle screw out and cut a slot in it so it can be adjusted with a screwdriver.
Old Sep 29, 2010 | 09:22 PM
whosdunit's Avatar
#2 yea , got to turn it back up, it would be easyer if i had a 28 in. screwdriver. But like i said it has been kinda pullin down at times ,and the idle was up plenty. thanks
rjm022
13
Jun 9, 2023 06:34 PM
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
