hx 35 ????
Old Aug 21, 2009 | 11:08 PM
1bad93's Avatar
hx 35 ????
ok i may be gettin an hx35 dont know for sure but maybe. but i have some questions on the install. i know that it bolts right up but should i spend the extra cash and get a new gasket for the maniflod and do i put oil in the turbo befor i hook up the oil line like you would an oil filter? and i plan on puttin the 60mm comp wheel and housing on it befor i install it on the truck does this go on just like the h1c upgrade?
Old Aug 21, 2009 | 11:30 PM
Mattster's Avatar
60mm wheel upgrade needs machining done to the turbo to accept the larger wheel, pretty easy job for a machine shop from what I understand. Thinking of having mine done before I put it on my rig.
Old Aug 22, 2009 | 12:16 AM
Your better off just putting the 60mm wheel on your H1C.
Unecessary to get the HX35 machined and install the expensive 60mm wheel, there the same specs.
Jon are you trying to use the 12cm wg housing the HX35 has or you wanna keep your 16cm ?? I think a 12cm would be fun on your truck but would get toasty EGT's too...
Old Aug 22, 2009 | 08:02 AM
Yes on the new gasket and pouring some oil in the turbo.
If you haven't already bought the upgrade kit, try running it stock for a while.
Install of the upgrade is similar, but the HX compressor housing is held by a big snap ring instead of a band clamp.
Old Aug 22, 2009 | 08:05 AM
You haven't run a 12 cm, have you? For any 5 speed truck that is stuck with a hybrid it is a much better choice than a 16.
Old Aug 22, 2009 | 09:35 AM
crewcabxlt's Avatar
hx-35 is a great cheap upgrade, throw it on with the 12cm housing,as said you,ll like it. the 12cm housing doesnt raise egt,s, pushing the turbo out of its map by overspooling it out of its efficiency map does,starts heating the air to much. put on the hx, push up to 32-35 psi and enjoy.
Old Aug 22, 2009 | 10:24 AM
TJE's Avatar
TJE
I agree. I pull a 30ft fifth wheel with the truck in my sig. and the only time I have problems with egt's is in the mountains. Just around town the egt's never get over 1000 to 1100 with my foot to the floor. It was a good upgrade for me.
Tony
Old Aug 22, 2009 | 06:50 PM
1bad93's Avatar
the reason i am puttin on a hx 35 instead of the h1c upgrade is because i want a wastegate. and also i its pretty toasty now and im tryin to cool it without breakin the bank.
Old Aug 22, 2009 | 07:05 PM
Mattster's Avatar
"Fit Notes (Please read before ordering);
This housing & wheel combo will fit all 1995-1998, 12 & 24 valve trucks, with a simple center housing machining procedure, if they have the O.E. part number turbocharger (attaches to the center housing with snap fing connection, not a v-band connection). The center housing must be machined to accept the larger compressor wheel major diameter. This is the only modification needed for these turbos." - From the GDS site
I don't know what a machinist would charge to do it.
Old Aug 22, 2009 | 07:07 PM
1bad93's Avatar
i just went to the gds site and seen that. does the hx flow better than the h1c i know its not much of a upgrade but is it at least a decent upgrade?
Old Aug 22, 2009 | 07:14 PM
Yes, the HX-35 is better than the H1C. Run it for a while and see how it is.
You should drill the center divider so it wastegates the front cylinders too.
Old Aug 22, 2009 | 07:16 PM
1bad93's Avatar
you mean the divider in the manifold? and what happens if this ant done?
Old Aug 22, 2009 | 07:19 PM
No, the divider in the turbine housing.
With big injectors and a 12 cm housing the front cylinders can push the boost past where the wastegate is set. Drilling the divider lets some of that pressure from the front scroll bleed into the rear scroll and keeps the wastegate in command of boost.
There are pics in my gallery of what needs to be done.
Old Aug 22, 2009 | 07:28 PM
1bad93's Avatar
ok thanks.
Old Aug 22, 2009 | 07:37 PM
1bad93's Avatar
so just open the port and drill a hole into the divider?
